Hi Conrad, how can I get to my notebook motherboard's battery
Need some help as far as getting my cmos re-set, how can I get on the inside of my notebook emachine M-5312 model. I've already unscrewed the screws on the bottom but can't seem to get it open to see if there's a jumper that I have to re-set, a battery in it. Don't want to force it I've tried most other avenues of trying to get it to boot, it did at one time but now I can't even get into my bios to re-do the settings? I did the Insert while powering up, same with the delete key while power up? neither seemed to do the job. Please Help, thanks I anticipate your expert response Michael I have worked inside computers before, but this one's got me perplexed?? 612-378-9173 [email protected]
    Problem Solver:
  • 50 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
47
Posted on Jul 25, 2009
SOURCE:
I need to rest password in bios
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all passwords and CMOS settings to be cleared. BIOS password can be removed by temporarily disconnecting/ removing the RTC/ CMOS (Coin-cell) battery from the motherboard.
Disconnect the coin-cell battery from the system board and it will reset the BIOS to its default setting and the password would be gone.
Please Refer to Page 29, 106 & 79 of the REPAIR MANUAL IBM T40 for Battery removal, keyboard removal and RTC battery removal instructions.
The Backup Battery (RTC, CMOS) is located under the keyboard. So you have to remove the keyboard to access the battery. The above Manual from IBM shows the exact method/ instructions and pictures for laptop dis-assembly for the purpose.
If you are comfortable with working inside such electronics, you can't do it yourself, or else you may seek help from local laptop service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | IBM ThinkPad T40 2373 Notebook
HP Compaq NC6000\r\nWhen I press the power button it seems to start but the only thing I see is numbers going by rapidly in the form of kbytes (524288 KB ok) then it reads 162-system Options not set. Then...
Hi promano67
When you "start" the computer, and the {"Screen"} displays a "Error Message."[CMOS] "error checksum!"
Settings: "Default" loaded.A "checksum error" shows that:
The ("Boot-up Settings "have been changed?"), ie. "Booting OS."
*Boot File 'missing'.
"This can 'occur' if the computer was "shut-down unexpectedly."
Force Shut-down : Power lost; due to 'low battery...'
A ("Power Surge") can cause this 'problem' also.
"What 'happens is that the [CMOS] settings are lost!".
"To fix the problem!"
Do the following:
  • "Restart / Boot the computer.
  • Next, verify if the 'error message' displays?
  • If you are still getting the message?
  • "You will have to "Remove the CMOS battery form the computer!"
  • Shut-down the computer.
  • "Unplug the computer from the {Wall Out-let}.
  • Remove the Lithium battery from the "Notebook."
  • There is a compartment (underneath) the "Notebook that 'store' the CMOS battery."
  • "You will need a {very small Phillips screwdriver}._953.jpg *Remove the CMOS battery for: [30 minutes].
  • !Important: If you have to do it again?
  • Remove the CMOS battery for a {'longer amount of time'}.
  • Replace the "CMOS battery."
  • Next, "Only plug the Power Adapter into the computer.
  • "Do not - replace the "Lithium battery!"
  • Once you have completed these 'task'.
  • "Restart the computer."
  • "Press the [F2] key, to 'enter' the CMOS / BIOS Setup!" _951.jpg
  • Next, 'reset' (all) "Values to the Default Settings."
  • "Press the [F10] key to 'Save' the changes!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Mar 13, 2011 | HP Compaq nc6000 Notebook
I forgot password for bios ,that is category extensa 4230 thank you advance
Hi
Just remove all the screws at the back of your laptop and remove the CMOS battery located in the motherboard to reset the BIOS setting.
Jan 11, 2011 | Acer Extensa 500T Notebook
I need to remove bios password from dell latitude x300
Hi there !
You can remove the BIOS password by removing the CMOS battery located inside your laptop and in the motherboard. Turn off your computer and remove the battery before opening the computer and remove all the screws at the back of your laptop to reveal the motherboard and remove the battery.
I hope it helps you. Good Luck
Jan 10, 2011 | Dell Latitude X300 Notebook
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
I need to reset password on my Acer 4230, and I can't find the cmos battery to remove
The CMOS battery looks like a small circular disc
http://www.tccycling.com/misc/5672inside.jpg
Just remove the connector hold for 30 seconds and plug it back in. Thats all.
Jan 27, 2010 | Acer TravelMate 2300 Notebook
I have a satellite A105 and When i turn it on it asks for password but I don't have the password. So how to I get past this to be able to use it again?
just remove the cmos battery
the bios stores the password and the cmos battery provides it power to store it
if you remove cmos battery the bios reverts to factory settings and the password is removed
cmos battery is different than the laptop backup battery
cmos battery is found inside the laptop case on the motherboard, you will have to open the laptop to remove the cmos battery
Sep 29, 2009 | Toshiba Satellite A105 Notebook
Acer 3001 Wlmi CMOS Dead
The best place to search the manual from this site link
http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/3b1edf692d19ce1e48256fd600068b2e?OpenDocument
the manual is here,it covers specs etc....
Have you tried ac power pack without battery attached?
if it is a cmos fault then battery will be on motherboard
battery number should be on battery
Jul 09, 2008 | Acer Aspire 3000 Notebook
Time settings
The Time And date Settings.
Are held Within The CMOS Battery.
This is usually on the Motherboard. ( Looks like a small round silver Coin )
They are quite easy to replace, usually about 3v-3.3volts.
Don,t change the CPU Or motherboard.
Just the Battery.
Mike @ Compurepair.
Mar 11, 2008 | ASUS P5RD1-VM Motherboard
Step to how to replce cmos battery toshiba 1805-s254
Hi!
If you already found the cmos battery, then try to check its "rating" and size to accomodate inside the board. After that fix it as it should be.
Dec 13, 2007 | Toshiba Satellite 1805-S204 Notebook
Open Questions:
AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]AVAST toll toll pHoNe {@}{\1888499-5520]
Oct 15, 2019 | Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
