There is a much easier way to solve this problem. get a reem of paper and put it in the machine.
next turn the power off hold down the left and right Print Position arrows and power up the machine.
when it boots it will show u a number. at this point you can let go of the arrows.
press the yellow clear button 1 time and the machine should show all zeros on the display.
enter the code 80 and press start. the machine will make a master. after that it will show you 80 again.
press the c button at the bottem of the keypad and it should show 0000 again.enter 888 and press start and set the print speed to the slowest speed possible. (if it keeps jamming try pressing stop and repeating above steps but with code 81)
this is the ink drainage mode it will keep printing until you press the stop key.when the image starts getting light press the stop key and turn the machine off and then on again. and the code should be gone!
