Question about Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder
Panasonic PV-HS2000 - Hard replacement
I need to replace my hard drive on my showstopper. How do I get the replayTV software on the hard drive so it will boot?
Thanks,
Ed
  • Tim Richards
    Tim Richards Sep 12, 2008
    I need to replace my hard drive. How do I get the software on the new drive? Thanks, Tim
  • Anonymous Mar 16, 2014
    Unable to connect to the Replaytv network. I pasid for repair of 2 HS 2000 recorders and was scamed.-Watch out for any .com's in So.Dakota
I successfully replace my Showstopper hard drive following the instructions posted at http://rtvpatch.sourceforge.net/utility.html
Posted on Jun 27, 2009
Just spoke with panasonic customer service team and he said to unplug and wait :30 seconds and then let the system roboot (which should take no more than 2 mins).
If it doesn't fix (which ours did not) then it most likely is the hard drive which will need to be replaced. You'll have to send to Panasonic Digital Service Center, 410 B Airport Road, Elgin, IL 60123. Fee is $149.95 + $30 return shipping. Put your return shipping info and payment within the box. Hopefully that helps. We got 7 years out of ours until these problems just started.
Posted on Oct 07, 2008
SOURCE:
Where do I get a new power supply board? Model # PV-HS2000
if you still want one i'm selling my nearly new unit.
modified with larger hard drive and screen covored vent holes for air flow
even added fans inside to move the air.
been in use a whopping 2 months, unfortunately i might not have a phone line to use it any longer.
Jan 26, 2011 | Panasonic PV-HS2000 Showstopper 30-Hours...
IR Blaster Code for DirecTV D12-300 Satellite Receiver
After digging around for awhile, the only onfo I could gather was that teh D12 uses the same codes as the D10 & D11, but could not get those codes, I am still looking around and will post any other info I may aquire. I would also suggest re-trying any codes for echostar. I can tell you this as I sell that equipment in my market and echostar provides the equipment and support for techs, installers, and retailers. Anyway Good Luck for now
Sep 26, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
I am trying to use a Panasonic Showstopper DVR
It records on one channel only, not a tuner itself...........
May 24, 2010 | Panasonic PV-HS2000 Showstopper 30-Hours...
Can the hard drive be exchanged for a larger one?
Either that http://www.weaknees.com/replaytv-showstopper.php
or buy yourself a hard drive and configure it following http://www.tomshardware.co.uk/forum/page-27662_30_0.html
Dec 05, 2009 | Panasonic PV-HS2000 Showstopper 30-Hours...
Panasonic Showstopper PV-HS2000
Yes, your hard drive has developed bad sectors. It will most likely need to be replaced. I am going through the same problem right now myself.
Feb 07, 2008 | Panasonic PV-HS2000 Showstopper 30-Hours...
No color or sound on DVD Player when hooked up with the ShowStopper
Svideo requires the audio cables too, Red and White. Svideo is only carries video.
Dec 30, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
PV-HS2000 Showstopper freeze up and noise
send to Panasonic Digital Svc Center, 410 B Airport Road, Elgin, IL 60123 - $149.95 + $30 return shipping. You have a bad hard drive and they will take care of it for you.
Dec 24, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Cannot down TV Schedule
1. Press Menu on the remote. 2. Choose Setup from the menu. 3. Scroll to Connect to ReplayTV Service Now. 4. If you don't have this option try this. For ReplayTVs running older software: 1. First, exit any menus you're currently in. 2. Press "2-4-3" on the remote followed quickly by pressing the "Zones" button - this will launch an informational screen, with like a 1-Exit, 2-Clear the Channel, etc. 3. Select #7, 'Net Connect' from the menu. (#4 on ReplayTV 2000 or 3000 series). A message at the bottom of the tv screen will indicate a successful connection. If you are unable to force a connection using this method, you may need to reboot your unit. This is done by pressing and holding the "Power" button on the front of the unit for 10 seconds. (Note: When you hear the fan in the rear of the unit turn off, your unit is rebooting.) Now repeat the previous instructions to force a connection. This is all found on the support site: http://www.digitalnetworksna.com/support/replaytv/document.asp?docID=87
Sep 22, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Panasonic PV-HS2000 Showstopper 30-Hours Video Recorder Logo
707 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
