Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Sony wega kdf-e60a20
Tv goes on and off every 30 seconds while the green light is still lit.
  • Anonymous Oct 22, 2008
    I had the same problem. Did the dust cleaning trick with the vacuum as mentioned by another. Everything is working great - took me maybe 20-30 minutes in all a little slower than the other but $0.00 for repari being the key.
    Problem Solver:
  • 4 Answers
My sony wega kdf-e60a20 had exactly the same problem 2mins on 2mins off no flashing red light just the normal green. I suspected a power supply problem. After some research I bought a new lamp for it (even though I was sceptical that this would work) It is extremely easy to change the only tool you need is an allen key wrench (for 1 of the 4 fasteners) Anyway it worked a charm and I realized my picture had been gradually dimming for some time. Haven't had a problem since and the picture is much brighter.
Posted on Oct 23, 2008
    Problem Solver:
  • 11 Answers
It works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I noticed a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
Posted on Oct 10, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Sony grand wega keeps turning itself off
Try to restore settings to default, if not try upgrading the software...... but iam pretty sure it is ur sleep timer ;)
Feb 05, 2014 | Televison & Video
KDF-E60A20. Picture and sound go off for a few seconds, repeats
It was as simple as replacing the lamp. It took just minutes and the TV works like new. I had to adjust he picture for the increased brightness level.
Oct 11, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Aug 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
On off on off on off
possible cause is the thermal fuse for the light bulb which is the back of the tv, next to the cooling fan.
Dec 29, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have this sony kdf-e60a20
lamp is monitored by an over-current protect circuit. When the lamp starts drawing a little more current than normal, the set starts shutting off the video and audio then in a couple minutes restrike the lamp. Unique to sony WEGA's, replace w/ new type xl-2200u, you should be o.k.
May 03, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
KDF-E60A20 Going on and off by itself..no blinking lights
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
hope this helps.
Dec 05, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
109 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
