Question about Sony PlayStation Portable (PSP) Console
Psp my chareter moves back and to the left. whats wrong?
  • bvakishore Aug 22, 2008
    i have update my psp slim from 1.05 to 3.90 using pandora battery
    .after upgrading the scrolling on the screen moves fast when game options are displayed.plase kindly tel me the solution.
    Problem Solver:
  • 13 Answers
Your analog stick broke, it's constantly 'pulling' back and left, that's why that happens. You should let your analog stick replaced by somebody with PSP hardware experience.
Posted on Oct 08, 2008
Hello sir..or who it may concern........while playing my psp or while going to my home page it suddenly goes to most left and then i cant go anywhere it stays right there.please tell me what to do...
I would suggest restarting the system. Shut down the PSP, remove the battery, let it stand for a minute or so, put the battery back in place, start up the PSP. When the PSP is starting, do NOT touch anything. Moving the control could cause the PSP to assume that moved position is the neutral base position. If this does not fix it, contact Sony directly.
May 28, 2011 | Sony PlayStation Portable (PSP) Console
My psp anolog stick is not working when i try to move it up+left what do i do
To calibrate your analog stick, go to the system information screen on your psp, and move your analog stick around in a circle as far out as possible.
May 17, 2011 | Sony PlayStation Portable (PSP) Console
When im turning on my internet on my psp it says, A connectino error has occured. The WLAN switch on the psp system is not turned on. What am i gonna do?
Ok simple there should be a switch that you can move left and right on the top left of the psp if not there look around the psp
Dec 26, 2010 | Sony PlayStation Portable (PSP) Console
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
After this try and see if it is reading UMD again.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
Psp wont play umd
Well, either there is something wrong with the game or the PSP is messing up. If i were you, i would take the game back in exchange for a new game, but get the same game. I would try it in the PSP. If it doesn't work then there is something wrong with the PSP. If the PSP still has a warranty, then you can contact the manufacturers and they could see what the problem is. If you don't want to do that and if you Just bought the PSP then exchange it for a new one. But if you have had it for awhile now, i don't think you could get a new PSP. So, i hope i helped you out some. Good Luck.
Jul 12, 2010 | Sony PSP (Piano Black)
My psp game gta lcs chareter is moving by its self is it the psp or the joysic or game help me plz
here is a simple answer all u hav 2 do is to go to a psp repair store and get that fixed or redownload ur gta liberty cities game again their might be something wrong when it was downloading like a virus.
Dec 21, 2008 | Sony PlayStation Portable (PSP) Console
Moving by self
the joystick's mechinisim must be faulty you must have a new joystick fitted
Need help on my psp
yep.
connect your USB (psp to pc)
hold left on your psp go into settings. tap up.
click USB connection.
DONE!
Aug 16, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick
try replaceing the stick but else i would take it into a store and get it fixed
Feel free to Email me: Thomashedderwick@hotmail.com
Aug 09, 2008 | Sony PlayStation Portable (PSP) Console
PSP GAME
My guess is you used a regular Q-tip to clean the laser lens and it left cotton hairs on the lens. I like to use the foam swabs. You can press the little swtich sticking up inside the UMD compartment. It is on the left and back about 1 inch. When you press it you should see your Laser light up and the spindle spin. This will tell you if the laser and spindlge work. You can physically move to Laser over to the right a few clicks and put the UMD back in it and look to see if the laser moves left and right. if it still does light up, spin the spindle and move left and right, then it probably will need its lens cleaned.
Jan 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
