Question about Bosch Axxis+ WFR 2460 Front Load Washer
Bosch wfr2460 I did replace the pump but still same message, what to ck for next?
  • rfdel Aug 23, 2008
    water is coming out, so no blockage, it is just pump never stops working til, message appear.
    Sergeant:
  • 236 Answers
After ensuring the sump hose and transfer hoses are clear clean out the pressure system to ensure the water wash level is not more than usual, secondly check whether the waste hose is not back filling from a sink u bend and also check the sink u bend for blockages (usually fat).
if all ok start to check the wiring connections from pump to pcb board, if these are ok then there may be a fault on the board. (pumping problems are usually easily solved with the above proceedure, the pcbs are rarely at fault for bosch but you may be the unlucky one !). tony
Posted on Aug 23, 2008
  • tony howlett Aug 24, 2008
    you may either have a pressure switch fault or pcb then.
Bosch wfr2460 washer not working after replacing motor with new motor- will not spin at all
Have you checked to see if it is wired correctly? Next, is there a run capasitor that goes to the moter, ir is it wired directly to the moter?
If it has a capasitor, you might need to change that. Any time you replace a motor, you always replace the capasitor with it. Let me know what you find out and we can move forward from there.
Oct 18, 2013 | Bosch Classixx WFC 2465 Front Load Washer
Leaking drain pump
Yes its very semple takes about 20min.
Jul 05, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Operation instruction
Ken,
Yes I have that manual, "Axxis+ wfr2450 & wfr2460" but it is a pretty big "pdf" file at 14MB. Let me know if you want me to send it, you`ll need to post your email address.
macmarkus :)
May 08, 2010 | Bosch Washing Machines
I have a Bosch Dishwasher. It will not drain. Our
ck the drain hose ( from the disposal to dw pump . ) you can not run dw with water due to the pressure sw . ck the drain pump also you can use a jumper test cord its 110 volts. .. may be the pump is bad .
Dec 07, 2009 | Refrigerators
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Dec 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch dishwasher not draining-I have cleaned the filters, checked the hoses. No know plumbing problems what's next? Is there a reset button?
make sure there is not air in the line and that the cage where all the water drains down into in not blocked or clogged. so first take the drain line out and completely empty it out. next ck the inside where the water falls down into to drain and ck for stoppage.
Apr 28, 2009 | Bosch Evolution 500 SHE55M05UC Stainless...
Bosch wfr2460 part number question
Try repairclinic.com  We were able to find parts for our Bosch WFK2401 washing machine and our Asko dishwasher...they list the part descriptions and show pictures.  It might take a few minutes to sift thru the things but i bet you can find your part.  FYI, shipping has been great...just a day or two to arrive after ordering.
Jan 11, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch WFR 2460 washing machine
the pum should do that but the magnet side may have saturated with water beyond the seal. i recommend replacing the pump.
Mar 16, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
71 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
