Question about Ricoh XR-10M 35mm SLR Camera
Shutter Release button
Hi! I recently bought myself a Ricoh xr-10m. After shooting 3 rolls of film I noticed that my shutter release button isn't always working? It's like, it only works after I turn it on. With 50% change of working. Kinda weird? Should I replace the battery's perhapse?
Thankyou!
Did you try changing the aperture? Depending on the lighting in the area, you may want to change this accordingly, if you put it in AUTO, and you're in a dark room the shutter might not open immediately.
Posted on Sep 14, 2008
When I insert the film, it won't catch, therefore I keep winding until the roll is done (also, the shutter release button won't depress). What does this mean? Is there a way to fix it?
When you say 'vintage', are we talking 35mm or roll film ? If 35mm, looks as if the interlock between shutter release and wind-on spool needs adjusting, but no idea if this is possible.
Aug 31, 2015 | Kodak Vintage Automatic 35 1959-64with...
My advance lever is stuck o my Ricoh camera. I had a roll of film get stripped in it and took it out in the dark room and developed it but now even with no film in it the lever won't advance. I've looked...
Your camera is in cocked position with shutter fully cocked and that is why you cannot advance the film advance lever. Set the shutter to x position ( on your shutter speed dial on the right hand side and top of your camera ) . The shutter should release and then you should be able to advance the film advance lever.
Oct 18, 2013 | Ricoh KR-30SP 35mm SLR Camera
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
Blank film
Make sure when you load your film, that the cogs are actually winding the film. Many a roll has been "shot" with the film ever advancing. If you see what your taking, that is really about all that it could be.
Jun 28, 2009 | Ricoh XR-10M 35mm SLR Camera
Mirror is stuck in "up" position and film will not advance
Normally, stuck mirror is due to weak batteries with a elcetromagnetic shutter like the Ricoh. Try with brand new silver oxides and see if it helps!
Feb 21, 2009 | Ricoh XR-10M 35mm SLR Camera
Sears ks-2/ricoh xr-7 film advance and shutter release problem
You probably need to take the camera in for repair. It sounds like the film transport is not connected to the shutter/mirror cage ***'y.
Jan 26, 2009 | Ricoh KR-5 SUPER II 35mm SLR Camera
Ricoh XR-10 35mm SLR camera
stevdan,
take the screws off the bottom cover. there is a small lever pointing toward the front of camera with a black screw on it. gently move it to the left, this will release the lock lever. Now advance the lever and the shutter should fire. if not, it is not repairable. no parts
Sep 12, 2008 | Ricoh XR-10M 35mm SLR Camera
RICOH XR-X PX
loloz
the four AA batteries go where you hold the camera under the shutter release button. right side.
Jul 25, 2008 | Ricoh XR-X 3PF 35mm SLR Camera
XR 7 locked up
Just read on another forum where the film rewind button can get stuck (little button on the bottom of the camera, used to initiate rewind), and removing the camera bottom allows access to unjam it.  I'll try... takes a small philips eyeglass screwdriver and young eyes (or my reading glasses...)
May 15, 2008 | Ricoh XR-7M II 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Photography Logo
195 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
