Question about Motorola Mobility RAZR V3
I can't access business phone menus with my V3 cell phone keypad
I have a V3 Motorola Razor. When I dial a business phone number like "my bank" for example that has a voice activated menu or directory system that says " to do this" press"1" or "do that" press "2" etc I press the numbers and the phone system on the other end doesn't recognize I've pressed the key on my end. Is there a setting on my phone I can change so this will work.
I have the same issue with an earlier version of the Razor. I haven't found a solution yet but still looking.
Posted on Aug 22, 2008
Phone start dialing when you open,this is a razor go phone with a real sim
Your phone keypad liquid ingressed or flex connectors to main board liquid ingressed check and clean up,try to swap another flip,if ok,that keypad faulty.replace it,if not check 2 IC small, near the connectors keypad could be corrosed clean them,hope to solve your problem.
Van
Aug 15, 2009 | Motorola Mobility RAZR V3
Motorola Razor keypad not working
integrated circuit might have got repaired you'll have to get that serviced
Jul 03, 2009 | Motorola Mobility RAZR V3
Black screen on motorola razor v3
I am glad I could help. I would appreciate it if you would rate this please. thanks...
Jan 13, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
Razor v3 problem using keypad durring phone calls "press 1 for this press 2 for that etc...
go to menu/settings/intial setup/DTMF - set it to continous then try the voicemail and try deleting the msgs again.
Oct 25, 2008 | Motorola Mobility RAZR V3
Phone unlock code for motorola razor
Press the menu on the keypad , now the phone should be asking you for the security code hopefully you have not change it from 000000 - default security code
Jun 06, 2008 | Motorola Mobility RAZR V3
Motorola V3 Razor
Guest - you need to take the phone and have the keypad replaced.
nende - you need to replaced the main-board or buy a new phone.
Apr 07, 2008 | Motorola Mobility RAZR V3
My V3 keypad is not responding
probably your flex connector get loose or defective... if you can open your fone try to check it... if not, just visit your service center..
Oct 31, 2007 | Motorola Mobility RAZR V3
Razor phone
take the back up of data & get the system software reinstalled from care center
Oct 22, 2007 | Motorola Mobility RAZR V3
V3 problem
Remove the battery. Hold the power key down for 30 seconds while battery is out of phone. Replace battery, and turn on the phone. Problem should be solved.
Sep 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
111 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
