Question about Lenovo Computers & Internet
It couldnot open at all. because a glass of water was poured into it by mistake.
    Problem Solver:
  • 44 Answers
Sorry to hear that....
Posted on Aug 22, 2008
SOURCE:
What are the advantages of using clear glass kettle?
Clear glass kettle are attractive, easy to pour from, and refill because of its large top opening. You will find many good functions on the advanced clear glass kettles like Breville and Cusinart. Cleaning the scale deposits from the inside is easy and much more.
Get some more details here: Top 5 Best Electric Kettle
Jul 28, 2015 | Kitchen Appliances - Others
Hypothesis concerning the effect of decreasing the temperature on the rate of production of gas from an alker seltzer tablet dropped in water
Reaction with water produces carbon dioxide fizz.
Baking-soda and citric acid react with water to produce sodium citrate and carbon dioxide.
If the water is below 32 degrees and in ice form, then the reaction would be slowed, and/or stopped depending if there was surface moisture on the ice.
Between 32 degrees and boiling, it might be possible that higher temperature water with more actively moving molecules could penetrate more quickly, and disperse the CO2 quicker allowing reaction to be faster.
Above boiling, when water is in steam state, which might be hard to contain and maintain, the table would probably dissolve as water vapor condenses on surface, but it would probably take longer than immersing tablet into glass of water..
Pour very hot water into one glass.
Pour very cold water into another glass.
Drop a table into each glass and see if there is noticeable difference in time before the tablet dissolves.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 10, 2013 | Water Heaters
Oster water kettle leaking from bottom of unit when pouring?
If you're not just simply missing the opening a little as you're pouring then I'd assume it's cheaper to replace than to repair, sorry.
If it's leaking from the side-glass you might get by with filling your kettle just under the lower end of the side-glass.
May 29, 2012 | Oster 5965 Electric Kettle
Glasses have a white, chalky film around the top of glasses
This due in part with the government mandate to remove phosphates from detergent.
Several things can be done to improve the clean appearance of your dishes.
1. Start a wash cycle with no dishes and no soap. Once the wash cycle has stated and water is circulating,open the door and pour in one quart of white vinegar and resume the wash cycle.
2. Use a detergent named FINISH.
3. Use only the recommended amount of detergent.
4. Periodically use a product named LemiShine.
Taking these steps will improve the quality and appearance of the dishes.
On a final note: too hot water temperature can cause etching in glasses and only a lower water temp will prevent new glasses from etching.
Jul 24, 2011 | Dishwashers
Hi cannot find wirless button on samsung laptop
First, plug your laptop into the wall. This allows for the laptop to be powered off the wall current. Next you need to get a large glass. Fill this glass with water and blue food dye. While the laptop is plugged into the wall, turn it on. Then you need to pour the glass of water on the laptop screen while closing it slowly. Leave the laptop alone for about five minutes after this, and then open the screen slowly. The screen should now display your configuration of where things like USB ports and the wireless button and settings are.
Enjoy!
Mar 17, 2010 | Samsung Laptop Keyboard for X20 X25 X30...
I can no longer unscrew the plastic part that the glass container fits into on my old Waring 18BL28 blender. It is a simple 10 speed that works perfectly.
Something sticky is in the threads... Try very hot water in the sink as a start, while boiling some water on your stove. With the glass and plastic preheated, install them to the blender base which must be unplugged for the rest of this adventure. Pour the boiling water in, only to about 1/3 of capacity. Install the top cover to protect from the hot water. Hold the glass by the handle and with a rubber glove on the opposite corner or pour spout side. Hold high to avoid the heat from the water. Have a large burly man hold the blender base so that you may twist the glass container counter-clockwise. Stop as soon as it starts to turn the plastic ring off...and go the the sink... Continue after pouring out the hot water. Remember that his procedure is likely to cause broken glass or broken plastic and exposure to scalding hot water. If those risks are acceptable you should still take precautions to protect your flesh. Otherwise order a replacement ring and pitcher for the blender.
Dec 23, 2009 | Waring Blenders
The drains on my sunroof leak when it rains and water comes inside the vehicle. How do I unclog the drains?
A big leak with that model is the drain tray in the rear under glass has broken loose. To check the drains, park vehicle on an down grade, open the glass and pour a cup of water in on each side and the water should come out the front, Turn the vehicle around to check the rear the same way.
Dec 10, 2009 | 2000 Jeep Grand Cherokee
Poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
GE Freezer Leaking
Open the freezer door, remove the bottom tray, smash the ice on the floor with your fist to remove it. Now get a glass of hot water and pour it into the trough which is at the bottom of the back wall of the freezer. Allow a few minutes for the ice to melt then remove it with an ice pick or scrrewdriver. Once the ice is out, pour more hot water into the trough. Now take a long tube ( an old washer fill hose works perfectly) and stick one end in the hole in the trough. Now fill your mouth with warm water and blow it very hard through the tube. Once the drain is clear, pour some hot water and a very little amount of bleach through the hole.
Apr 06, 2009 | GE Refrigerators
Water spilled on laptop....LCD screen appears fainted...?????
Don't worry, water won't damage your screen permanently and will 'evaporate' in time, but for now you have to live with the effects it has on your screen. It will be more like a few months then days but it will heal in time
Hope This Helps
Nov 21, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
26 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
