Question about Pioneer Audio Players & Recorders
After having stereo receiver hooked up for more than a year, the receiver now reads OVERLOAD and shuts off while all other components work. Swapped out surge protector, no luck receiver still reads OVERLAD.
    Genius:
  • Pioneer Master
  • 1,550 Answers
My dear friend the audio amplifier IC´s are damaged you need to replace him.
Posted on Aug 22, 2008
My Sony MHC-EC55 Mini Hi-Fi Component System stereo wont work. i turned it on then it shut off the red light started blinking standby button.. i unplugged it then plugged it back in turned it on ..then it...
This usually means an overload. On my daughter's system it was because she had extended the speaker wire and where she has spliced the wires the two sides were touching. Try un-hooking your speakers and turn on the system. If it works without shutting off then you can reconnect the wires one speaker at a time. Maybe you have a short in the wire or speakers.
Mar 02, 2011 | GPS
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a technics sug91 amp the over load light comes on what can i do to remove it
you cant remove the overload light. it does that as a safty so you dont burn up the amp when its not being used properly. do u have a capacitor? are the speakers ohms and watts the same as the amp?
Oct 18, 2009 | Technics SA-AX540 Receiver
No sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Feb 16, 2009 | Sony CDX-CA700X CD Player
No sourround sound
read your manual well and double check all your connections,make sure the remote is working, check the battery contacts in it too. If you haven't got a manual, obtain one.
Sep 29, 2008 | Denon AVR-1706 Receiver
VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Dec 22, 2007 | Pioneer VSX-D498 Receiver
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Overload
try turning the unit off in standby mode then hold down the enter button and then the power button for about 10m seconds that should reset the unit depending on how new the unit is it sometimes has a digital saftey setting but i doubt that would cause it to do what you are saying
Oct 17, 2007 | Pioneer VSX-D411 Receiver
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
