Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SD-p5073-K Shuts off
I have a pioneer rear projection tv and recently the unit stopped powering on. When you unplugged the unit from the wall and tried it again after a few minutes it would click on the off again. I pulled the wires from Socket E8 and now the unit powers on but there is a thin line shown on the screen. What does that wire group attach to, I tried to follow it and it seemed to attach to the board that is mounted vertically in the front of the set.
  • sdorner Aug 30, 2008
    shuts off intermittently and now will not power on
  • theburt Oct 07, 2008
    I have a pro-610hd. it also shuts off after I turn it on. I have to turn off the main power for it to reset the protection circuit and then try again.
    Problem Solver:
It is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Posted on Dec 02, 2008
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer 5065 tv
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement. Good luck
May 25, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer sd-p5073-k am in the process of replaceing the converinage chips. and cant seem to find any pico fuses anywhere on the converange board or main board there are several regular fuses on the main...
Make sure to check all the fuses with an ohm meter. Pioneer also have terrible solder joints. I used to "sweep solder" the whole convergence board. Down on the power supply you should find the pico fuses. They are pretty small in compairison to the glass fuses.
Oct 14, 2009 | Televison & Video
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
Pioneer SD-P50A5-K 50 inI
Hi, I am just curious. What is going on wih the Television? Thanks, Mike
Nov 04, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P55A5 Shuts off and must be reset with Main Power Switch
if you are not a tech take your set to be repaired your tv illness is in the power supply or related circuit.good luck.
May 14, 2007 | Pioneer SD-P55A5K 55" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
522 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
