Question about Dryers
When dryer turns sounds like something is banging around in there
5 year old frigidaire heavy duty washer and dryer stackable
model # flse6orgs2
serial # xe32600375
Replaced the barren
Posted on Aug 23, 2008
SOURCE:
Hi there, I am trying to find the year of the washer/dryer stackable combo unit that I have. It is a Frigidaire Heavy Duty 27" model. Model number is MLC275CW5 and the Serial number is XE92196352. ...
5/99 is the date,if you want to find out dates on any other appliances you can go to appliance 411 and enter the model and serial numbers,brand name and what appliance you're looking up and it will give you the date.good luck
Aug 08, 2011 | Frigidaire Washing Machines
We have a frigidaire gallery, heavy duty, stackable washer dryer. The dryer has stopped spinning. No grinding or anthing just not moving. Belt?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 22, 2010 | Dryers
BOUGHT A USED STACKABLE FRIDGIDAIRE AND NEED THE PLUG FOR IT, WHERE CAN I GET IT? WHERES THE MODEL NUMBER ITS A HEAVY DUTY CROWN SERIES
The Model number could be on the top of the machine or around the dryer door or by the washer lid. if your looking for a 220/240 volt 3 prong cord you should be able to get one at lows or home depot
Jan 09, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Sep 03, 2009 | Frigidaire FEX831CS Top Load Stacked...
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
A loud bang .....like a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Feb 14, 2009 | Frigidaire Washing Machines
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Dec 20, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
206 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
