Question about Dell E152FP 15" Flat Panel LCD Monitor
BLACK MONITOR THE SCREEN TURNS BLACK AFTER THREE SECONDS. I CAN SEE THE XP LOGO WHEN TURNED AT AN ANGLE, I AM TOLD THAT I NEED TO CHANGE THE CAPACITORS ON THE INVERTER BORAD. PLEASE TELL ME WHICH CAPACITOR AND THIER VALUE/PART NUMBER. THANKS
    Genius:
  • 1,550 Answers
Why don´t you try first to resolder all the crack joints on the main board maybe that solve your problem.
Posted on Aug 22, 2008
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
Nov 08, 2015 | Sony XBR-52LX900 BRAVIA LX900 Series 52 3D...
Vizio VO47L FHDTV10A black screen no light
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
?Check the cables, connectors and connections.
Take it to a repair shop.
Apr 11, 2014 | Vizio VO47L 47 in. LCD TV
TOSHIBA LED 46L5200U TV where picture stoped working and the volume is working
Check and replace its back-light inverter board. Contact any service technician. Gopakumar Gopalan Google
Feb 24, 2014 | Toshiba Televison & Video
Windows xp black screen after lg logo solutions
Press the three key Ctrl+Alt+delete from your keypad when you see that black screen with cursor blinking,the scree will come up automatically or else try to switch the notebook in safe mode by following these instruction:
1. Turn on the notebook and keep pressing the F8 key from your keypad
2. You will find options like --Safe mode
--Safe mode with Networking
--Start window Normally
3. You need to select the Safe mode with networking option and then press enter from your keypad
This way you can get into the safe mode and you can easily use the notebook.
If the information helped you then please give me some ratings.Thanks
Jun 02, 2012 | LG E500 Express Dual Series Notebook PC
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Capacitors can be faulty even if they look OK. The problem is with the backlight inverter circuit. The actual backlight tubes are probably OK since the display lights for 2 seconds. Try changing any capacitors on the backlight inverter board even if they look fine, especially if they are low value ones e.g. 10uf. If this does not work then you will need to replace the inverter board. You can buy a universal inverter board from on-line sources such as ebay. You will need to determine the correct connections for the cables. The three connections you need are positive supply - usually 12V, negative - 0V, On/Off signal - usually 5V.
Mar 02, 2011 | Computers & Internet
Black Screen After Windows XP Logo
Try and start in safe mode and uninstall the game
Apr 08, 2010 | XFX NVIDIA GeForce 8500 Graphic Card
Same problem 2 seconds on, then turns black
The problem with the monitor is the power inverter board. I took my monitor apart and tested all the power outputs. The ones going to the main board where ok but the ones going to the backlight where different. I changed the three capacitors on the power board that where located between the two heat sinks I think it was the 1000uf and the two 470uf. They looked ok but when i tested them they where off. Next on the opposite side of the board with all the little componites there are a few dry joins that you have to resolder. If you cant find then you can just resolder the whole back board it should only take 30min. If you have no idea what i am talking about i would not sugest taking the monitor apart.
Jul 03, 2009 | Gateway HD2200 LCD Monitor
Microtek 997M monitor doesn't stay on...
The inverter is the most common item to fail on a LCd monitor. Capacitors usally fail the most. Are the tops of any of them popped up. If you had any shorted transistors the fuse would probably be blown. Usally labeled F1. I would replace all the capacitors first and go from there. Capacitors are cheap.
Jun 20, 2008 | Computers & Internet
Dell E152FP 15" Flat Panel LCD Monitor Logo
66 people viewed this question
Alun Cox
