Question about Panasonic KX-T7630 Corded Phone
Forward to voicemail
I dont seen to have voicemail set up...how do i do this and then forward call that are not answered to voicemail??? thanks
  • Panasonic Master
  • 2,460 Answers
It depends on what you mean by not set up. Voicemail has specific steps to make it work and it starts with admin access to both the voice mail and phone system. If it is already set up (ie you can call 165 or whatever the VM number is), then what greeting it plays will give you an idea if what needs to be done.
If it plays a general greeting like when you call in from outside, it may be that you just need to add the mailbox for your extension. If it doesn't answer at all, then it's probalby time to call an installer.
Carl
Posted on Aug 27, 2008
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
Lucent partner 34D calls go directly to voicemail
Sounds like either you have do-not-disturb activated, or you have call-forward-all to voice mail set. You should have call-forward-no-answer turned on but it's easy to enter wrong code. Find a list of codes for your system and see if its one of those.
Apr 19, 2014 | Lucent Lands Phones
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Model
You may download a copy of the manual at http://www.home-electronics.net/ge/pc/IB/29490GE2_IB.pdf.
The 29490 isn't an answering machine. To set up the voicemail, please consult the documentation for whatever answering machine or voicemail system you have on your phone line.
Call forwarding is a service provided by your telephone company. With many systems, dial * 7 2, wait for a second dial tone, then dial the number to forward to. Answer that other phone to confirm. Dial * 7 3 to cancel. If these instructions don't work then contact your telephone company for their instructions regarding call forwarding.
Jul 26, 2013 | GE 29490GE2 Corded Phone
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
Transferring call to my voicemail
DK system call forwarding in icm #604 for forward busy and no answer
Jun 19, 2009 | Toshiba DKT-2010 Corded Phone
User's voicemail box is not answering the calls
There is also a setting for What extension to forward to..
Terminals and sets, forward busy and fwd no answer.
Forward on busy is no set correctly.
May 13, 2009 | NorStar CallPilot 100
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
Norstar 7310 forwards to Voicemail
Sounds like the phone is set for Call Forward Busy/ No Answer instead of Call Forward No Answer. If you cahnge it call forwarding it should work correctly. ....Mike
Aug 08, 2008 | Nortel Norstar 16-Line PBX Speakerphone
I want to set Call Forwarding to OFF and it wont
You need to erase your voicemail number you put and set it to off again.
Sep 28, 2007 | Motorola Mobility RAZR V3
Panasonic KX-T7630 Corded Phone Logo
223 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
