Question about Sewing Machines
Rex blindstitch model L118-2
My blindstitch machine missed the thread loop very often. It is very noisy compared to when I first got the machine 10 years ago. How do I know if it is out of timing and how to correct it? Any repair book or source of help I can rely on.
Thanks for any advice.
Thinh Le
tle893@yahoo.com
3 Suggested Answers
SOURCE: What type thread do I use for a blindstitch machine?
The short answer is: You can use any type of thread that is suitable for the garment. Regular sewing thread, serger thread, etc.
Longer answer: Some like to use monofilament thread because it is clear and goes with any color, but it is hard on the machine and can actually wear grooves in the thread guides.
I really like to use Gutermann Hemshire U151. It is a fine polyester thread that is very flexible and works great in a blindstitch. I order it from Atlanta Thread and Supply (www.atlantathread.com). Their prices are reasonable and they ship quickly.
Posted on May 04, 2009
  • 436 Answers
SOURCE: need a downloadable instruction manual
No luck findong your but Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful.
Good luck
Thanks
Posted on Apr 11, 2011
Manual for Rex518 blindstitch machine
Try Googling (rex)(518)(manual) without parens.
May 22, 2017 | Sewing Machines
How to adjust timing for Rex blindstitch hemmer
As long as your machine is not skipping stitches the timing should be fine. Three things to check: take your thread tension assembly apart so you can remove the discs and clean. Debris often gets between them and causes irregular tension. Next check the point of the looper to see if has a burr. If so take 600 sandpaper or crocus cloth and remove. Last-Check the upright pin that the looper passes--it too may have a burr.
Mar 24, 2015 | Rex RX-518
Missing parts on singer sewing machine model 974 serial no. SH30010021
take it back to place purchased .have them correct the problem
Mar 15, 2017 | Singer Sewing Machines
Need a downloadable instruction manual for Rex RX-518 blindstitch hemmer sewing machine please!!
Good luck
Thanks
Apr 11, 2011 | Rex RX-518
How do you adjust timing on Rex commercial blind stitch?
I was just researching the same issue, only for my Lewis Blindstitch. I found a copy of the US Blindstitch maintenance manual on the mansew.com webstite. It looks like the setup is very similar to my machine, so maybe you can adapt the information to yours also. Good luck. Sorry, I was not able to post the hotlink, but this is it spelled out, exactly as it shows.
http://www.mansew.com/US BLIND/USBlindstitch_Maintenance.pdf
Apr 30, 2009 | Rex RX-518
Mar 12, 2009 | Rex RX-518
REX blind hem how to lock the stitch
When I purchased my blindstitch machine, I was also told to kind of snap the fabric as you pulled it our of the machine. Like you, I found that to be a little risky. Sometimes I'd just unravel what I'd sewn. I have found the most dependable thing to do is: Before removing the fabric from the machine, snip the thread between the fingers of the looper as it approaches the needle. If the loop is broken, the chain stitch will not pull out. If you cut the loop as it approaches the needle, you will get a bit longer tail so the needle doesn't come unthreaded on the next run. If you find you need a bit longer thread tail, you can pull a bit on that loop before cutting. As long as the needle has passed through the loop on the previous stitch, you'll be fine.
Dec 29, 2008 | Rex RX-518
HOW TO THREAD
Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful. I have the Rex518 with the original instructional manual, but the translation into English was very poor. The MSK555 is published so you can understand the manual, and figure out how to use your machine. I too am a first time user of a blind hemming machine.
Good Luck.
May 29, 2008 | Rex RX-518
Sewing Machines Logo
294 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
