The error could be due to the cartridges not properly installed on your printer. Try to open the printer cover and remove the cartridges > close the printer cover > re-brick your printer by
pulling out the power supply - the black box where the power cord is
plugged into. Re-plug after 30 seconds. > when the printer turns on, reinsert the cartridges. Try to print again to verify that the problem is fixed.
Make sure the Lexmark X6570 printer driver is installed on your iMac desktop. You can download and install the X6570 printer driver by visiting the Lexmark website at http://bit.ly/hVA0vj. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
The Lexmark X6570 printer uses these cartridges:
- #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem:
1. Remove the print cartridge that is indicated and close the cartridge carrier lid.
2. Close the scanner unit.
3. Disconnect the power cord from the electrical outlet. Wait a few seconds.
4. Reconnect the power cord to the electrical outlet.
5. If the power button is not lit, press it to activate.
6. Reinsert the print cartridge and close the cartridge carrier lid.
7. Close the scanner unit.
8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Is your printer setup to print "wireless"? Does it have a wireless card in it? You may need to try hooking it up to a wireless router to be able to printer from your laptop.
Good day.
Usually that happened once the printer was not set to default setting after it was installed.
To set to default, click start, choose printers and faxes, select the lexmak pinter, click file select default printer.
To test your printer if it print.
1. right click the printer icon
2. select properties
3. click print test page
