Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator side by side not working properly.
I have a GE side by side refrigerator model # ZIS42CMC and serial # SF032124. The freezer is working but the refrigeration part has stopped cooling. What should I do?
Carol
  • crice27 Aug 23, 2008
    What does diy's mean? The condenser seems to be working OK. Freezer is still working, refrigeration is not cooling.
    Brigadier General:
  • 6,966 Answers
In most instances where the freezer is working but the fridge is not is caused by failure of cold air flow due to:
  • defective, stuck, iced over blower fan;
  • clogged, obstructed, iced over air pathway/tunnel (in some);
  • air vent/port blocked;
  • defective fridge thermostat.
All of the above require disassembly and test of some parts which would be a DIY (do-it-yourself). Should you be uncomfortable performing this and unfamiliar with electrical/electronic components, circuitry and tests, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 23, 2008
    Master:
  • 623 Answers
Check your condenser...or let a repairman check it i don't think there is diy's here
Posted on Aug 22, 2008
  • ritchie dempacco
    ritchie dempacco Aug 23, 2008
    diy''s=do it yourself
    take it to a repairman
    good luck
I have GE refrigerator model ZIS42CMC. How do I remove the evaportor coil from the evaportor compartment so that I can access the defrost heater?
you don't as to do that will loose all the gas and you will be in a bigger cost zone than having a technician fix it
Jul 10, 2017 | GE Refrigerators
GE S-Series Side-by-side refrigerator
you ll change the temperature control unit,since its not performing optimally
.thanks and godbless
Sep 29, 2008 | Refrigerators
GE side by side refrigerator not working properly. Fresh food side is warm. Freezer side is at 9 degrees. What could be the problem?
Check for ice buildup at back of freezer. If so then auto defrost mechanism is not working. Check for bad defrost timer, heater, and defrost thermostat.
Oct 17, 2015 | GE Refrigerators
Serial #
What problem are you having? All you need is the model number.
Jul 05, 2013 | GE Monogram ZICS360NRRH C... Bottom...
Brought the GE WR55X10942 Refrigerator Main Control Board, and I am getting ready to install it, it saids to eliminate thermistor wire in pin 2 of J1 connector for any encoder models that starts with a...
Yes you will need to cut the wire the directions states all bottom freezer models and models with certain serial numbers... But you will not need to do other modifications specifically for bottom freezer only models.
Jul 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge working not cold no freezer section
first you should check the termostate how much temp you keep.then if your compressor is working properly so check the refrigerant in system.it may be more chances lake of the refrigerant.oil increase in L.P side.you also should check the thermostate is proper working or not.chaces of low pumping in the comp.either door gasket likage or freezer door ofently open.
Feb 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
May 20, 2009 | GE Refrigerators
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is not working properly.
http://forum.appliancepartspros.com/refrigerator-freezer-repair/4220-ge-refrigerators-gs-ps-models-evaporator-fan-motor-test-replacement.html
Try this link with step by step instructions
hope it help
Mar 06, 2008 | GE GSS25LGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
