Question about Compaq Presario Notebook
My monitor display got rotated 45 degrees somehow. Buttons were pushed accidently. I cant get to turn back to normal display. All icons and display are set up where I have to open notebook like a book to see.Please help. Program is VISA
  • 94 Answers
After logging on to the windows.... just press Shift Key + Down Arrow key...
Posted on Aug 22, 2008
SOURCE:
My computer screen pic has turned 180 degrees how do I change it back to normal view
From control panel open the display option or depending on your type of video card you may have an icon that has the name of the card. open that. there should be setting to rotate.
Feb 23, 2015 | Computers & Internet
Rotate screen back to normal
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Feb 23, 2013 | Gateway Computers & Internet
My nec multisync FE991SB monitor screen is turned upside down
Option One:
Try using the keyboard combination, "Control + Alt + Up Arrow Key". Control + Alt along with one of the arrow keys is a fairly common rotation hot-key configuration and may just do the trick.
Option Two:
See if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
Option Three:
If neither of the previous options help, try the following procedure.
  1. Right-click an open area of the desktop and click "Properties" to open the "Display Properties" window.
  2. Click the "Settings" tab and then click the "Advanced" button to open the monitor settings window.
  3. Click the tab corresponding to your graphics card. You may need to click one or more buttons within the tab to reveal a rotation settings option. Exactly where rotation settings are located will depend on the brand of graphics card installed.
  4. Once you locate the rotation settings, choose the "0 degrees" or "normal" option to change the display to upright. The rotations settings may also give you the option of disabling rotation hot keys so that the problem does not happen again.
  5. Click "OK" to save changes and exit out of any open properties windows.
Aug 09, 2011 | Computers & Internet
HP (Altec Lansing) monitor is displaying sideways, my friend lent me her laptop
Some graphics cards have rotation "hot keys" enabled by default and this is probably the most common cause of this problem. The exact procedure for rectifying the display may depend on the particular brand and configuration of the graphics card in the problem computer. One of the following options may help resolve the issue.
Option One:
Option Two:
If Option One doesn't work, see if there is a graphics card icon displayed in the Notification Area (near the Windows Clock). Clicking (or right-clicking) the icon may reveal a "Rotation Settings" option that will allow you to revert to "normal" display.
Option Three:
Jan 30, 2011 | HP Computers & Internet
After turn on of computer all pictures in the monitor are face down
try this...
Option One:
Option Two:
Option Three:
DO REMEMBER TO VOTE FOR THIS ANSWER IF IT HELPS...................
Jan 18, 2011 | Computers & Internet
My computer monitor display changed from being horizontal to vertical how can I change it back?
If you have an Nvidia Graphics card then on the bottom right hand side of your task bar, next to the time, it's a green icon. A Nvidia logo is displayed. Left click on it and move your mouse over rotation settings, should be set to rotate 0 degrees.
Can also access through control panel, then Nvidia control panel, then on the left menu rotate display, set it to no rotation 0 degrees.
Please take the time to rate my expertise.
Thanks
Oct 31, 2010 | Computers & Internet
My acer aspire one netbook display was rotated 90% counter clockwise by accident. How can I restore the display to normal
Right click on the desktop away from the icons. Scroll down untill you see something like ati or Nvidia control panel. Select that and look in the left hand side for either screen orientation or screen rotation. Choose 0 degrees or landscape.
You can also get to these settings through the control panel > display settings > Screen Orientation > Landscape.
Jun 21, 2010 | Acer Aspire One AOA110-1113 Netbook
My monitor display has rotated itself 90 degrees counterclockwise and I do not know how to return it to it's normal position. What do I do to return it to it's normal "Landscape" position?? I have a...
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
Aug 05, 2009 | Panasonic Toughbook-19 Tablet PC
Monitor display is rotated 45 degrees. Can't get it back to normal.
right clik on the desktop and select graphic options then choose rotation. set to normal mode. fine ???
May 03, 2009 | HP Compaq Presario SR1110NX PC Desktop
Compaq Presario Notebook Logo
102 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
