Question about Acer Aspire 5100-3357 Notebook
Xp logs on then logs off immediately on acer 5100
Turns on, goes to user names, I pick any of them, it starts to start up then before getting to log on it says savings settings and logging off, any suggestions?
  • grobfamily Nov 24, 2008
    Same thing happens to my daughter's Dell Inspiron Windows XP...4 different user accounts; log onto any (including Admin) and immediately logs off.SAFE mode doesn't help.....does anyone know what virus does this ??
    Seems it mught be easier to fix/repair IF it had a name that I could earch for.
    THANKS- Aaarrgghhh!
  • Anonymous Dec 30, 2008
    i found a problem
    Scholar:
  • 64 Answers
I'd suggest booting into Safe Mode (press F8 after the POST information is finished on bootup) and then you should see an option for Administrator. If you can sign in successfully there, go to Control Panel and create a new account under User Accounts. Boot normally after that and see if you can sign in the new account.
Two questions: 1) is this XP or Vista? and 2) did you recently make any significant changes to the software (namely try to change the Certificate of Authenticity)? If what I suggested works, I'd say boot into Safe Mode again and then run System Restore for Windows. Set the system back to about a week ago and try logging in normally.
Ben
Posted on Sep 17, 2008
I lock my computer a for got the pass code.
If You are using a windows XP, the solution is for You to turn on the laptop allow it booth, once it gets to the log in page, press the ctrl+alt+delete button, then a page will come up, You will have the page where You will have to enter the user name and the password, just type Administrator in the user name and leave the password blank and press enter or log in, it will log in for You, there You can access the user profile and change the password through the control panel.
If You are using the windows vista, then when You get to the log in page, then You press the control+alt+delete button, then You select start new task, then the computer will log in with a neutral profile, after it has one that, then You can go to the control panel and change the password for the user profile You used to lock the password.
Hope this helped.
Thank You for using FixYa
Jun 10, 2011 | Acer Aspire One Netbook
Tip
How to copy data from a corrupted user profile to a new profile
Create a New User Profile in Windows XP Professional loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Click the Advanced tab, and then click Advanced. 5. In the left pane, click the Users folder. 6. On the Action menu, click New User. 7. Enter the appropriate user information, and then click Create
Create a New User Profile in Windows XP Home Edition loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Under Pick a task, click Create a new account. 5. Type a name for the user information, and then click Next. 6. Click an account type, and then click Create Account
Copy Files to the New User Profile loadTOCNode(2, 'moreinformation'); 1. Log on as a user other than the user whose profile you are copying files to or from. 2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK. 3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from. 4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat • Ntuser.dat.log • Ntuser.ini 5. On the Edit menu, click Copy. 6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section. 7. On the Edit menu, click Paste. 8. Log off the computer, and then log on as the new user.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
I have 3 accounts on my acer desktop computer. Now for some reason mine and my moms doesn't work. So now we have been using my dads. Whenever we try to log on, it just says "Login Failed" and we...
You cannot log into your accounts? Try going into the one account you can log into, and removing the passwords from the other accounts in the "Control Panel"
For windows Xp Try
  1. Click on Start and then Control Panel.
  2. Click on the User Accounts link.
    Note: If you're viewing the Classic View of Control Panel, double-click on the User Accounts icon.
  3. In the pick an account to change area of the User Accounts window, click on your Windows XP user name.
  4. Choose the Remove my password link.
  5. In the text box on the next screen, enter your current password.
  6. Click the Remove Password button to confirm that you'd like to remove your account password.
  7. You can now close the User Accounts window and the Control Panel window.
  8. Now that your Windows XP account password has been deleted, you will no longer need to log on to Windows XP when your computer starts. Windows will now load all the way to your desktop automatically.
Jan 09, 2011 | Acer Aspire™ T180 PC Desktop
Logging in problems
Download minipe, put it on an usb stick, go in the bios by pressing del or f2 when your laptop just starts booting and change the boot sequence to usb first, when in minipe at the harddisk part press on chkdsk.
Jun 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
I bought an Acer netbook and my daughter wants a larger laptop. I can't remove her name. She signed on and dowloaded windows XP. Is there a way to remove her as administrator. I bought it from a small...
Go to control panel > user accounts > create new user > name the new user something like "PC User" make the account type administrator and hit apply, log out....then log back in under the PC User name. When you are ready, delete the account that has your daughters name. It is in the same drop down menu as you were in to create a new account.
Oct 20, 2009 | Acer Aspire 5100 Notebook
Turn on computer comes up to windows page with no pass words
It sounds like it might be getting to the user accounts and not being able to log in. I would start by going into safe mode--> Right before the windows splash screen comes up, start pressing the f8 key. Then when it gives options, choose safe mode. If it gets to the user screen this means its either something in your startup, or the user account files.
Once in safe mode, you can select the administrator account, and create a new user account, to see if you reboot to normal mode and it lets you log in as the other user.
Sep 06, 2009 | Acer Aspire 4315 Notebook
Desktop keeps logging off when I click on user name
press ctrl alt del at login screen and use the manual method, also press F8 when starting up and choose safe mode
Apr 18, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Start Menu Picture Disappeared Suddenly
Turn the Welcome screen on or off It sounds as if you accidentally turned off the welcome screen. Here's how to turn that function on and off:
To turn the Welcome screen on or off
You must have a computer administrator account on a computer that is a member of a workgroup or is a stand-alone computer to turn on or turn off the Use the Welcome screen feature. Logging on at the Welcome screen is not available on computers that are members of a network domain.
  1. Open shortcutcold.gifUser Accounts in Control Panel.
  2. Click Change the way users log on or off.
  3. Do one of the following:
    • To specify that users log on to the computer using the Welcome screen, select the Use the Welcome screen check box. A user logs on to the computer by clicking his or her user account name on the Welcome screen. If a password is assigned to the account, the user is prompted to type it.
    • To specify that users log on to the computer without using the Welcome screen, clear the Use the Welcome screen check box. The Welcome screen will no longer appear when you start the computer. To log on to the computer, type your user name (and password, if you have one) in the standard Log On to Windows dialog box.
note.gif Notes
  • To open User Accounts, click Start, click Control Panel, and then click User Accounts.
  • Fast User Switching is available only when the Welcome screen is turned on. For more information, click Related Topics.
I hope this helps. Please let me know if you require further assistance.
Feb 26, 2009 | Microsoft Windows XP Professional SP2
Keeps logging off
If you are using WINDOWS XP then at boot press F8 and you'll see a Start-up Menu... scroll down to the option LAST KNOWN GOOD CONFIGURATION... Hit Enter and Start Windows.. Best of Luck.
Plz Rate me.
Thanks.
May 14, 2008 | Acer TravelMate 2500 Notebook
Acer Aspire 5100 will not log on
If you have a Finger Print scanner (on select models), it may have failed, if you do not have this device , you may have installed malware - try rebooting and after you see the Acer screen start tapping F8 to get to speacial boot menu - choose Safe Mode and see if you can log in. If still unable, you will have to perform a system recovery - Acer provides an alternate way to recover - when you start the computer you see the Acer logo screen - after this displays hold down the Alt Key by the spacebar and tap the F10 key at the top of the keyboard once or twice - this will start the Acer E-Recovery program - follow the on screen instructions.
Jan 30, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100-3357 Notebook Logo
392 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
