Question about Symantec Norton AntiVirus 2002 8.0 for PC
Yesterday I shutdown my computer and came back to start it up again today and it is much much slower and responding very slowly. I was looking around to see what was going on and I realized that Norton was disabled but i cant find a way to get it back running its virus protections. (By the way, the computer asked me if I wanted to run Vista in safe mode and i did numerous disk checks...) Please help i really dont know what to do.
  • 3 Answers
Have you tried defragging your computer.
or change settings on desktop
Posted on Oct 22, 2008
Light is on where the electrical cord is plugged in but cannot turn computer on
Hard to say exactly what is wrong with the limited information you provided but...
It's fairly common for laptops to get stuck is "Sleep Mode" and exhibit this behavior.
If that's the problem, you can try the following...
Unplug the power adapter from the computer, remove the battery from the computer, then press the startup button for a few seconds. Without putting the battery back in, connect the power adapter and try starting the computer again. If this works, shutdown the computer, put the battery back in, and you should be back in operation.
Good Luck!
Dec 29, 2012 | HP Computers & Internet
I have a Briggs and Stratton 7000 watt propane generator. When running this morning after two hours, it quit. It starts back up for about three seconds or so then quits again. I put a new tank on...
does this engine have a low oil shutdown unit on it
if so check the oil level an top it up it could be interupting ignition
be sure your tanks are full and connections are good and tight
brush soapy water around connections to see if any have a leak
if not oil level shutdown , then sounds like a fuel problem
suggest have a gas serviceman take a look
these units can be tricky to solve
Aug 11, 2010 | Briggs & Stratton 15,000 Watt Home Standby...
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
The computer shutdown and I tried to turn on and
If you are getting through the bios before it shuts down, you may want to make sure that the CPU cooling fan is working and that there is plenty of airflow around the CPU heat sink. Make sure the reset and power buttons are working properly as well. Check that all of your RAM modules and any add on cards are seated properly as well.
Jan 03, 2010 | HP Compaq Presario F500 F700 and G6000...
2005 DB9 / crank no start
pull out negative terminal battery located under rear right seat.wait for 5 min n then install again the lead negative terminal.insert the key to ignition cylinder.turn the key on off three times.now start the engine.make sure u use recommended fuel grade.
May 13, 2009 | 2007 Aston Martin DB9 Coupe
Keyboard not responding or responding slowly to key strokes
do the batteries need changed
if so make sure you shutdown first
or check settings for keyboard in control panel
Jan 08, 2009 | Dell R6053 Keyboard/Multimedia Control...
Will not power on
First try disconnecting ALL power to the laptop - not just at switching off at the wall but pull the plug and remove the battery as well. leave it for 30 seconds or so and put it all back and try again.
If no luck then press F8 on boot until the boot options screen appears and select 'Last Known Configuration'
If no luck then is this XP or Vista?
Dec 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Won't turn on when I press the front button
This sounds like your power supply; it's the part that the power cord plugs into that converts the power to dc and powers your motherboard, drives, and everything else inside your computer. You can pick one up for around $30 online or $80 at a retail store.
Thanks and please take a moment to rate as fixya.
Sep 08, 2008 | Dell Dimension 2400 PC Desktop
Alternator problem
Buy a OEM alternator, preferably one from the dealer. Many alternators found at parts stores are rebuilt used ones.
Aug 22, 2008 | 2001 Ford Taurus
Symantec Norton AntiVirus 2002 8.0 for PC Logo
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
