Question about Lexmark Z715 InkJet Printer
Lexmark Z715 printer
Paper started jaming and now unable to use printer
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.IF the problem continues then its the problem with rollers in the printer ,hardware problem ,
Good luck....
Posted on Dec 14, 2008
I have a Lexmark Z715 Printer. It has a paper jam I cannot clear - picked up about 15 sheets of paper at one time and I cannot get it unjammed. Is there a trick to solving this problem?
Some sheets are jammed more tightly than others. Check to locate and remove the less jammed sheets to make it easier to remove the rest. With some printers, it helps to "riffle" the supply first to prevent sticking. You also may have loaded the printer with more sheets than it can handle at one time.
Nov 01, 2013 | Lexmark Z715 InkJet Printer
I have a lexmark z715 printer connected to windows xp. recently it stopped printing. the paper moves and the machine makes sounds similar to printing, but it doesn't print. i think the sound is s
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 23, 2013 | Lexmark Z715 InkJet Printer
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
Lexmark z715 snowleopard incompatability
I have the same problem. I have a Lexmark Z705.
It stoped working after l installed snow leopard!
tell me if you get it to work!
Oct 08, 2009 | Lexmark Z715 InkJet Printer
Lexmark Z715 printer feed paper
The feed rollers might be dirty from the ink. Try cleaning them with a Q-TIP with a little isopropyl alcohol.
Jul 31, 2009 | Lexmark Z715 InkJet Printer
Installment of lexmark Z715 printer
Here is a link for the download page for the drivers. Just enter the model # which is Z715 and select your OS and you can start you reinstall: http://downloads.lexmark.com/perl/downloads/downloads.cgi
Jan 13, 2009 | Lexmark Z715 InkJet Printer
LexmarkZ715 inkjet printer
Here is the Lexmark Support page:
Lexmark Support
Enter your printer name (Z715) and it will take you to the support page for it. Click on Download Driver. Next select your operating system. You can choose the driver or utility software from the next page.
Oct 20, 2008 | Lexmark Z715 InkJet Printer
Lexmark printer model z715
yes.. go to...
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
under search model enter.. lexmark z715
enter operating system.. xp/vista/linux?
download.
best to save to a file in case you need it.
Sep 21, 2008 | Lexmark Office Equipment & Supplies
Lexmark z715 trouble
you got the freshest vista drivers? get em here
Mar 13, 2008 | Lexmark Z715 InkJet Printer
Lexmark Z715 InkJet Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
