Question about Haier HTE21WAAWW Top Freezer Refrigerator
Fan is a big issue. New problem though.
I bought this Haier HTE21WAAWW Top Freezer used. Big surprise, the fan motor was dead and would not work. I finally replaced the fan motor (any idiot with a 3rd grade education could do it) and the fridge works wonderfully. One exception to this though is now there is some water dripping down from the air vent hole in the refrigerator from the freezer. Now the freezer is working great, doesn't seem to be melting, what could be done to remedy this? Also, if anyone could tell me, is 7 or 1 the highest setting? It's a little confusing. Should I have it on a middle setting to keep the freezer freezing and the fridge nice and cool?
  • 32 Answers
Good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Posted on Apr 09, 2009
SOURCE:
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
How will you know the fan in the top freezer part is bad.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Jan 25, 2011 | Haier HTE21WAAWW Top Freezer Refrigerator
My refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
Jan 05, 2010 | Haier HTE21WAAWW Top Freezer Refrigerator
Water dispenser not working & fridge and freezer not getting cold
okay, most likely, your problem is your fan motor, its making your evaporator becoming a block of ice freezing your water lines but its not circulating the cold air through your refrigerator. remove the panel from inside the freezer and see if it has become a big white block of ice and the fan motor is turning. some fan motors will not work with the door open so you must manually press the light switch and see if the fan is blowing air.
if fan blades are not turning, replace the fan motor. but if it is blowing air and there's a big block of ice, unplug your fridge and let it thaw out. if after melting your fridge is running again, there's something wrong with your defrost system. that means check and replace your defrost heating element, defrost thermostat and or defrost timer.
i hope that helps with your problem. good luck!
Jun 10, 2009 | Frigidaire FRS23H7CS Side by Side...
Hole in freezer of haier refrigerator
The refrigerant used since ~ 10 years is no more dangerous than the one previously used and it is even doubtful that the newer stuff is any better for the ozone layer.
The original coolant could be inhaled without injury as long as one didnt suffocate from a lack of oxygen.
The repair may not be cheap since it will entail the removal and replacement of the damaged coil.
This will require some specialized welding to install.
Using a normal table-top or floor-standing fan to circulate ambient air through the refrigerator with the door(s) open is a safe and fast method for defrosting units that do not automatically defrost.
Just make sure you have some absorbant material in the bottom to avoid water running out of the unit.
Poking the coils with sharp objects can result in the problem you now have or fracture hidden joints that will allow the gas to escape.
Jul 19, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Haier
In units with physically separate sections, there is a fan that circulates the cold air between the two with some provision for adjusting the airflow to balance the temperature between the two chambers.
The cooling system is normally a totally closed loop that is charged in the factory through a nipple that is then pinched and welded shut.
This nipple must be cut and resealed to recharge the system.
Jun 01, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Freezer fan stopped working
Sounds like you need a new fan motor. First make sure the fan blade turns freely and see if you can move the shaft side to side, or up and down. If you can feel any movement in the fan shaft the bearings of the motor are bad. It is possible for some ice to have the fan blade frozen causing the motor to stall. Some models also have a fan light switch install at a point near the hinge side of the door.
May 02, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Refrigerator
check to see if your condenser fan in the freezer is working
Nov 27, 2007 | Haier HTE21WAAWW Top Freezer Refrigerator
Haier HTE21WAAWW Top Freezer Refrigerator Logo
230 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
