Hi, whenever I turn on my wireless reception , a MS Dos-like, blue screen pops up and my computer reboots. The error centre said it is a wireless adaptor problem. Please help.
    Genius:
  • 1,027 Answers
The blue screen of death is caused by a problem associated with the drivers for the wireless adapter. It is commonly called a "STOP ERROR"
download and run everest home from this site
click on Network, click on windows network. this will ID the wireless card you are using. google the card for updated drivers.(or e-mail me at mewms_14904@verizon.net
Posted on Aug 22, 2008
ASUS P5B blue death screen after rebooting windows 7.
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 27, 2012 | Computers & Internet
When the computer boots, it display bluescreen
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
Two computers have the same IP address
On either computer:
Get a dos prompt, by clicking start, run and type in cmd.
In the dos window type in "ipconfig /release" then "ipconfig /flushdns" and finally "ipconfig /renew". This should give the computer a new IP address.
If these steps fail due to some error popping up, reboot the computer into Safe Mode with Network, If you are still having the IP issue, run the dos window again and try the same commands. Then reboot the computer back to normal windows.
Hope this helps
Jan 30, 2012 | Computers & Internet
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
Error saying master file corrupt...
HELLO THIS MIGHT HELP WITH THE BOOTING IF YOU CHECK AND MAKE SURE YOU ARE BOOTING OFF THE CD DRIVE IF YOU ARE THEN MAKE SURE YOU HAVE A GOOD COPY OF WINDOWS . NEXT TRY SHUTTING OFF YOUR COMPUTER AND RESTART HITTING F2 OR F10 IT SHOULD BRING YOU TO A START UP PAGE
May 20, 2009 | Acer Aspire 5315 Notebook
Wireless Internet causes blue screen of death
-- "limited conn.."-- you should configure the internet connection in the router's software ie 192.168.2.1 or any other IP for the router, use ISP help desk for this (if it's free).
Blue screens have numbers and sometimes explanations, usually they pop up because of incompatible driver, chek router software(driver) compatibility.
explanation of blue screens are in the following link:
http://www.aumha.org/errors.htm
May 05, 2008 | Dell InspironTM 600m Notebook
Wireless malfunction
your wireless internet card is faulty, and your notebook sounds like its got an overload on memoy.
heres what you do:
- get a new card
and
- get a memory upgrade
hope this helps,
Maxicube
Feb 09, 2008 | Toshiba Satellite M30 Notebook
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Blue Screen
Not good. You should return it immediately. Once you open it up, there is no more warranty. Memory dumps are usually caused by either a hardware problem or by corrupt or outdated system files. If there is no warranty, it has to be opened up and the connections checked. Could have been caused by a fall but it probably is a bad contact inside. If for some reason you cannot return it or there is no warranty, contact me again and I will help you through the procedure.
Oct 30, 2007 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
