Lexmark X1240 All-In-One InkJet Printer Logo
Posted on Jun 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer light is flashing and I am unable to print
Prashant Sharma
Level 3:
Genius:
  • Master 1,127 Answers
  • Posted on Jun 22, 2011
Prashant  Sharma
Master
Level 3:
Genius:
Answers
1127
Questions
0
Helped
237233
Points
3825
Hi
Follow the mention below option.
1) Check the printer door, it will close properly.
2) Check you don;t have any paper jam. if you see the jam paper remove that one.
3) Check your cartridge fix properly.
4) See the lnk level, if ink level in show empty then change the cartridge.
Anonymous
Level 2:
New Friend:
  • Expert 95 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
95
Questions
0
Helped
11801
Points
262
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
1helpful
2answers
HP Laserjet 1022 orange light keeps flashing
1. Check any paper jams in side.
2. Check cartridge.
3. Remove back cover, clean paper sensors.
4. Replace Formatter board.
Alarm light flashing and unable to print
dear sir
my printer mp180 pixma show flashing alarm and check printer pls solve it thanx Raj
2answers
We have the E260d. What does it mean when the light bulb flashes. We are unable to print. What can we do?
You can unplug the printer from the wall, then leave it off for about 30 seconds then plug it back in. That should reset the printer, if not read what the message says on the screen, or you may have to navigate through the settings to see the error message.
Switched printer on to print unable to print drum light flashing-
Remove and reinstall drum / some times will reset drum switch.
Or the drum life has been used. Drum only good for 8 to 10 thousand copies.
1helpful
Print unable 4F
nandkjwatson,
Good day!red light flashing causes some problems on your printer.Like empty inks,no paper,hardware error.Be sure to check all ink cartridges if its full and if all chips are good.Be sure to have paper loaded.
Regards,
Mastergani
2answers
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
4helpful
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Unable to print
wireless print, scan and copy unable to print anything
2helpful
2answers
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
