Question about Canon CLC 1120 Color Copier
Xerox my machine was in a fre, only smoke in air, i cleaned &blew out every nook&crannie, but i still get a message after i turn it on, it starts& i choose the paper size, choose the color, it takes all of that while i wait for the machine to warm up, the lamp come on & moves, the a message comes up stating that a #& to turn it off & wait 20 sec.& that i should call the dealer, i no longer have a warranty, so all that they tell me is that it means that a lamp is exposed, how many lamps does a xerox have? i don't know the exact # on the xerox as it is at work. can you help me or tell me where the other lamp is , if ther is another lamp?
  • Canon Expert
  • 1,326 Answers
They have a scanning lamp and a fixing heating lamp. Xerox is funny when you need some free advice. They don't..... I work on every thing but Xerox, you may want to get in touch with a company called "Parts Drop" on the web. They have Helped me in the past before... Good Luck
Posted on Aug 22, 2008
In general, how do I clean my computer?
Using an air compressor give it the mother of all blow jobs in every nook and cranny. Your computer will be very clean and very happy!
Jan 09, 2016 | HP Computers & Internet
I want to clean my compact CD player
First I would try a can of "canned air" commonly found in computer stores. Put the little res straw into the nozzle and use it to blow out your CD player. Stick the straw into every nook and cranny. THat may do the trick, if not,. just start opening the case and blow off what is inside, being careful to remember how to close it back up.
Aug 17, 2014 | Audio Players & Recorders
Galaxy Centurion cell phone
If your nook and cranny search did not include Galaxy, you may have missed the best source for the information.
Oct 22, 2013 | Televison & Video
To clean can I 1) hose it down with a dishwasher
This isn't recommended, meat tends to get in a lot of the nooks and crannies in a slicer machine. It's best to first unplug the machine, then take it a part in order to properly clean it. If your not sure how to take the machine apart, consult the user's manual for further understand how to do it. Once taken apart, some sort of stainless steal cleaner followed by a sanitizing soap should be used to clean it. Sanitizer is very important especially when dealing with meat products. Once a sanitizer is applied it is recommend that you let the slicer air dry for 4-6 hours before using it again to ensure the sanitizer has fully dissipated.
May 18, 2011 | Berkel 827E Gravity Feed Deli Meat Slicer
My SS785 smoke detector "chirps"
The unit may simply need cleaning. As dust and lint will accumulate on the unit and in the senors.
You can accomplish this with a can of compressed air with a straw nozzle (like you clean your computer with). Carefully remove the cover and blow out all the nooks and crannies of the detector. If you can't remove the cover, stick the straw nozzle into any opening you can see and give it a quick blast of air.
The detector may alarm due to the COLD air from the can. But, should stop once it warms back up.
You should clean all the detectors in the house at least every 6 months.
I find it unusual, that there is no battery backup in your detector. What happens if you have a fire during a power outage?
Feb 23, 2011 | Universal Security Instruments SS785...
Our smoke alarm with battery backup keeps chirpping every 30 seconds
You didn't mention if you had replaced the battery, yet. If you haven't, then that's more than likely the problem. Also, it probably needs cleaning. You can accomplish this by using canned compressed air (like you clean your computer with). Use the straw nozzle to reach all the nooks and crannies. Clean after removing the old battery and before installing the new battery. Batteries should be changed annually and at the same time clean the unit. When using the canned compressed air, try to keep the can in the upright position, as much as possible.
Jan 25, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Hello i have a 1986 Honda fourtrax 250 2wd atv and i just bought it. the previous owner stated that he hit a ditch and it flipped. once turned back over it would not start. 2 years later i buy it and it...
Pull the carb and throughly clean it after sitting the old fuel will turn to varnish and clog everything up. also if the machine was on its top check the oil and make sure it is clean. leaking gas is a indicator that you will probably need a carb kit for it that must include the float valve and needle.
Oct 29, 2010 | Honda CB 250 Motorcycles
I have a 125 thumpster it will satart with the chock on and will run with the chock on if i turn the chock of it will die if i try to ride with the chock on it will back fire what do i do
That is a sign of carb problems! You will need to remove it and disasembel it and clean every nook and cranny. Use carb cleaner and a air compresser.
Dec 20, 2009 | 2002 Yamaha TT-R 125
Gateway MT3705, model number is W340UI. How do I disassemble it?
Go to any good office supply store and buy a tin of compressed air.
Or go to a spray shop who use oil free lines.
Take the battery out and give the machine a good long blast
Better still take off the main covers underneath before you do so
Make sure that you do not use any air supply that has oil or water in it
Aug 24, 2009 | Gateway MT3705 Notebook
Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Canon CLC 1120 Color Copier Logo
35 people viewed this question
old marine
old marine
