Question about Motorola Mobility RAZR V3
Phone numbers How do I program a pause after an entered number to dial an extension?
  • g-turner Aug 22, 2008
    Thanks for the quick response...gosh I hate feeling so dumb:)
Hi gt,
Just enter the letter p, which will pause.
HTH, ;-)
Posted on Aug 22, 2008
SOURCE:
Panasonic phone model kx-ts108w how to change emergency to a new number on this phone
Page 20 in the manual
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdf
PDF]Operating Instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/telephone/om/kx-ts108_en_om.pdfIntegrated Telephone System. Model No. KX-TS108W. Pulse-or-tone dialing capability. Operating Instructions. Preparation. Basic Operation. Advanced Operation. Useful Information. PLEASE READ BEFORE USE AND SAVE. Panasonic World Wide Web address: http://www.panasonic.com for customers in the USA or ...
20
Storing Phone Numbers
You can store up to 20 phone numbers in the one-touch auto dial buttons
(10 numbers in UPPER memory locations, 10 numbers in LOWER
memory locations).
Make sure that a call is not put on hold.
To store in an UPPER memory location
It is recommended that you program an emergency number in the
EMERGENCY button.
Press
(PROGRAM)
Enter a phone number, up to 22 digits.
If you enter a wrong number, press
(PROGRAM)
and start again from step 1.
Press one of the one-touch auto dial
buttons.
A long beep sounds.
The unit will return to the standby mode.
If 3 beeps sound, the number entered in step 2 may be over 22 digits.
Press
(PROGRAM)
to return to the standby mode, and start again from
step 1.
If a pause is required for dialing, press
(PAUSE)
where needed. Pressing
(PAUSE)
counts as one digit (p. 24).
When using the Dial Lock (p. 27) or Call Restriction feature
May 01, 2018 | Panasonic Lands Phones
How i can change extention number to new one (i have 4 telephones in house)?
This can be done through system admin programming. From the programming phone, press program key then **1234(1234 is the default system admin password). Enter 003 for the program code then enter. Dial the present extension number followed by the new extension number, then press enter. Press end or lift the handset to finish.
Dec 12, 2010 | Panasonic KX-T7735 Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
I WAS RE-PROGRAMMING MY AUTO DIAL BUTTONS AND WAS ON MY 3RD ONE WEHN IT DECIDED THAT ALL MY BUTTONS WOULD NOW DIAL THAT NUMBER. i CAN'T TOUCH A SINGLE BUTTON WITHOUT IT DIALING THAT NUMBER.
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
Aug 12, 2009 | NorStar M7310 Corded Phone
Fax problem. Trying to send international fax to France. I can hear the fax number being dialed ok, but no connection after 12 rings. Calling fax number from phone hooked up through mp530 connects ok! ...
Hi ...
It might be possible that the line is loose or the long distance calling code is incorrect. Follow the below instructions which might resolve the problem.
Sending Using a Long Distance Calling Code The telephone company or PBX system may use long distance calling codes on a phone line as a means to manage long distance calls. This service may extend to a fax phone line and for local phone calls as well. To use a calling code for faxing, enter a pause (or pauses, as necessary) in the dialing sequence to allow time for the phone system to distinguish between the phone number and the calling code. For example, if the calling code has to be entered after the phone number, press <Redial/Pause> after the long distance number and then enter the calling code.
Here is an example of a couple of variations that may be used by the phone company / PBX system. (For details on time sequence between the long distance number and when you must enter the calling code, please contact your phone company or telecommunications specialist.)
Long distance number: 212.555.1212
Calling code: 123456
Scenario One: 12125551212p123456 Scenario Two: 123456p12125551212
Note: The above scenarios include a pause (p) in between the dialing sequence. This pause may be necessary to allow the phone system to detect each set of dialing sequences. The pause length can be adjusted from one to nine seconds, the default is two seconds.
Tips to help you send a fax using a calling code.
  1. To send a fax using a calling code, it may be necessary to add a pause(s) before the next string of dialing digits. The above example shows how a calling code is used to dial a long distance fax number. To provide time before the calling code number is dialed and avoid misdialing, a pause should be added.
    Example: 12125551212p123456
    The number of pauses will depend on the phone / PBX system.
    It is suggested to confirm if the time before the next set of digits is dialed will always be constant. This way you can always use the same number of pauses for that dialing sequence. If needed, you can also change the pause [Pause time] length from its default 2 seconds.
  2. Connect a telephone to the fax machine.
    1. Connect a line cord from the telephone wall jack to the [L] jack (or item <1>) on the fax machine.
    2. Connect a line cord from the extension telephone port on the fax machine (top jack (or item <2>)) to an external telephone.
  3. To send a fax using a calling code, it is recommended to dial using the attached telephone.
    1. Press the <FAX> button on the operator panel.
    2. Insert the documents face-up on the ADF.
    3. Pick up the handset of the attached telephone and confirm you hear a dial tone.
    4. Dial the fax destination number on the attached telephone.
    5. When you are prompted to enter your calling code, dial it on the attached phone.
    6. When you hear the remote fax machine's high-pitched receive tones, press <Color> to send a color fax or <Black> to send a black and white fax. The audio signal heard from the handset will be cut off.
    7. Hang up the handset.
    8. When the transaction is complete, the fax machine will return to standby mode.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA® MP530 All-In-One Printer
Programmed speed dial - internal calls
To add an Extension Key: -
DONT lift handpiece, enter [*91] then press a vacant memory key and then choose “Repdial Key” from the menu. Enter an extension or group number and press the [ü] key.
To dial an Extension Key: -
Lift handpiece.
Press the memory key you programmed.
Storing a personal speed dial number: -
Lift handpiece.
Dial [*92]
Dial memory number.
(*0 - *9 for personal numbers)
Press the [ü] key.
Dial 0 then the number to be stored.
Press the [ü] key.
Hang up.
How to dial speed dial numbers: -
Lift handpiece.
Dial [*7]
Dial memory number.
(001-999 for system numbers)
For Example: [*7*0 ü] will call the personal number stored under position *0.
[*7001 ü] will call the system speed dial number stored under position 001.
Jan 19, 2009 | Siemens optiPoint 500 Standard Corded...
Programming new numbers into kx t7630
If it's going to be an extension press PROG dial 1 and the ext number and ENTER
If you're trying to put an outside number on it, press PROG dial 2 then 9 + number and ENTER
Carl
Nov 27, 2008 | Panasonic KX-T7630 Corded Phone
Brother faxes 8360P and 8000P - how do I progamme the machine to dial a 9 before each number please ? as my machines are connected to extensions on the PABX. Thanks
As I'm aware you can not program a number before every number you use. However you can progam the one touch or speed dials you can enter the 9 before the numbers. On some systems thay may need 9 then a pause then the number.
Nov 14, 2008 | Brother Office Equipment & Supplies
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
