Question about Panasonic VDR-M70 DVD Camcorder
Error Code no.0280
I am getting the "error code 0280, please read manual." I followed the directions, and still it does not work. Any ideas?
Sounds like the wrong media in the disc drive ex. dvd-rw will only take dvd-r and dvd-ram disks if that helps anyone have a link for the drivers and or the install disk for this camera plz post
Posted on Mar 18, 2009
Dryer won't spin belt good
Your problem says dryer but the category says washer. I wrote this answer thinking the problem was washer. Sorry but I haven't had opportunity to fix my dryer before so can't help you there. If however your problem is the washer (or is anyone else is reading this), please read on... you should find some ideas here.
First you have to check the error code. If your washer does not have a digital display you have to do the following:
1. press any button to "wake up" the machine.
2. press and hold the start and pause buttons.
3. count the flashing lights.
a) first the five lights plus the start light will flash. Count.
b) then the start light will flash. Count.
4. error code is E +# of times in a + total # of flashes in a and b.
Example: flashes start light plus all five lights 4 times, then a pause, then start light alone 3 times. Error code is E47.
There are lots of error codes but E47 and E43 are both door problems. Check out the following document for a lengthy (but understandable) troubleshooting guide. E47 and E43 both say to do Test 9, which is test the resistance of the PTC. If it's not working then you have to replace the door latch assembly (about $80), if it reads around 1500 Ohms you have to replace the control board (about $250).
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf
First, let me say that I have no idea how to test the PTC but it can't be hard with a standard multimeter (I will be doing this tomorrow with my Dad).
Second, the removal to access the door latch assembly is stupid easy - check out the following YouTube.
http://www.youtube.com/watch?v=prkM2XMoOJk
Third, if you have a different error code just look up the test in the manual document above.
Hope that helps!
Dec 15, 2012 | Frigidaire Affinity ATF7000E Front Load...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
For more help visit cbrtechsolutions
Mar 27, 2012 | Belkin Surf N300 Wireless N Router
Disk error 0280
Error 0280 on Hitachi mv350a DVD camera : It looks the dvd had bad spots that could not be read. After getting frustrated trying to get any info from Hitachi manuals and support, I just decided to try to extract the data directly from the dvd(fujitsu dvd-r disk). Since my DVD was not finalized I could not copy the files directly using Windows Explorer, so I tested several applications and here it's what worked for me: I downloaded isobuster (www.isobuster.com), and I was able to view the tracks on the dvd, then I used the "Extract" option to create an image directly from the faulty dvd and it created a couple of files with the extension .ibq. I checked these ibq files and two of them were huge, so I assumed those were my video data. I renamed these files from *.ibq to *.vob(isobuster has options to extract these "image files", but you need to register it first...), anyways I tried to open these new vob files with PowerDVD and they PLAYED JUST FINE :)! Finally I just used a DVD editor to load the new .vob files and I burnt a new DVD. I hope it will save you guys some time... Mihai from Romania :)
Oct 09, 2009 | Hitachi DZ-MV380A DVD Camcorder
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
BROTHER MFC 5840cn MACHINE ERROR 4F
Downloaded service & repair manual for brother mfc 5840CW- my unit. Will follow repair directions to check the memory then replace required parts. Will be cheaper and faster than finding a repair shop and paying as much as the macine to fix it! Rip off prices for repairs today on units so they can get you to leave them and buy a new one. Then they fix the unit and sell it "refurbished"- not mine!
Your information on clearing memory, the ink cleaning codes and taping the cartridge from over cleaning was good. Thanks for the help!
Jul 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
Panasonic VDR-M70 DVD Camcorder Logo
304 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
