Akai LCT3201AD 32" LCD TV TV will power on for 1-2 seconds, then shut off. I have checked power connection and changed outlets...same problem.
  • sammyboy9 Aug 23, 2008
    viore tv bought at walmart about 1 year ago shuts off all by itsself now the volume is starting to get fuzzy and go up and down
  • 2,337 Answers
The power supply is defective and needs to be replace or repair.
Let me know if you need further assistance or you can write to [email protected]
Posted on Aug 22, 2008
SOURCE:
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
Tv turns on for a few seconds then turns off
Change input device to some other like a DVD player and see. Look for any loose contacts in power outlet or jammed buttons on remote or on control panel.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 03, 2012 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide screen lcd tv/dvd combo LCT3201AD
This may be an instance were the idea was great but the execution wasn't thought out. I've heard of several related problems that may be related. Both the TV and the DVD player tend to produce heat, not in great abundance, but together a sizable amount of heat. The power supply may have been ample for the TV at first but with the addition of the DVD player was not able to handle the extra load. If still under warranty you're all set. If not you might call Akai and see what they might be able to do for you.
Sep 29, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used ShopJimmy.com in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
http://www.shopjimmy.com/megmeet-mlt168a-power-supply-unit.htm
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
Won't power on.
Check to see if the cord is plugged in to the wall. Check to see if the wall outlet has power. If it does it may be the power supply or a burnt fuse in the TV and will need to be serviced.
Nov 22, 2010 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD won't turn on. Plugged in and
you have a power supply problem there are caps in the power supply that fail the will be bulged on the top these have to be replaced in most cases or a fast switching diode
or get a replacment power supply and exchange it
Oct 24, 2009 | Akai LCT3201TD 32 in. LCD Television
Television will not turn on with remote or from the tv itself. The red light is on, so it is getting power and we have tried other plugs, so outlet is not the problem. Akai 32" LCD TV/DVD Player Combo...
there are capacitors on the power supply that will be vented or the top bulged out
those will need to be repalced to correct the problem
1000mfd 16volt caps
Power supply
I found THIS weblink having info for Akai LCD TV parts. Please check it as it might help you.
Aug 06, 2008 | Akai LCT3201AD 32 in. LCD Television
Need a stand and remote control for Akai LCT3201AD
Please check this Weblink as they might help you to provide desired parts for you Akai LCD TV.
Jul 27, 2008 | Akai LCT3201AD 32 in. LCD Television
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Nov 14, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Ekse
