Question about Sony Cyber-shot DSC-W100 Digital Camera
Camera turns itself on!
I've actually sat there and watched the camera, in the off position, turn itself on. I turn it off, it turns on... and so forth. Naturally when it does that in the case the battery dies... any ideas?
  • micksta81 Aug 22, 2008
    I actually have exactly the same problem. To turn the camera on, I have to press the 'Playback' button. Then to switch it off, I have to hit the power button as per usual. But in a matter of a few seconds, the camera turns itself back on again! this keeps happening. Any solutions for this?
    Regards
    Mike
  • Anonymous Sep 05, 2008
    Same exact problem here. Sent the camera back to Sony repair depots twice and both times -- despite extensive documentation of the issue and symptoms associated -- they claimed to be unable to reproduce the problem. The only thing I could think to try on my own to fix it was use a different battery (in case the first battery was flaky and somehow triggering the camera to power up). Same "ghost" power-on problem occurs using the new battery.
Has demons need to be exerzied
Posted on Oct 27, 2008
My samsung Cameras lenses were sat on and now they dont work
Camera's and lenses are not to be sat on. ;-)
It's probably bent or something got broken within the lens itself. There is no other solution than have the lens/camera repaired or buy a new one.
Dec 30, 2013 | Cameras
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
When camera is switched on, the screen show WRITE PROJECT above a KEY image. Camera is E1055W. I've no idea how this has been turned on and cannot find how to turn it off. HELP please. ...
The write protect tab is on the SD memory card itself. Just remove the memory card from the camera, find the little tab on the side of the card, and slide it to the other position. For others experiencing this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 12, 2011 | General Electric E1055W Digital Camera
SD card Locked
The error code 000060 means SD card locked. The switch on your card may be unattached internally. Try a different card.
May 17, 2010 | Moultrie MFH-DGS-200 Digital Camera
Pentax optio s6
This is exactly how my problem started. Then after repeated attempts to turn it on or off the lense actually stuck in the on position. After GENTLY forcing it in the off position, it began turning on and would immediately turn back off. After reading every problem posted that had to do with the lense I figured that the lense had somehow worked it's way of the "track or gear" that moves it in and out. I don't recommend this solution unless you figure that the cost of having it repaired proffesionally would be more than to replace the camera (I am a trial and error type of repair person). On my camera, also an S6, when the lense came forward and began to retract, I GENTLY held the lense in place for just a second. I repeated this probably four or five times until it "worked itself" back into the proper position. It does make the clicking noise while doing this which made me a bit nervous but it worked. The camera actually even seems to be focusing better which leads me to believe that possibly it hadn't been quite right for a while. AGAIN... you have to decide if the cost of proffessional repair is worth it to you. I am not a pro but this worked GREAT for me. Hope it helps.
May 18, 2008 | Pentax Optio S6 Digital Camera
DMC-LZ3 ASKING TO TURN CAMERA OFF AND THEN ON AGAING AND AGAING
this is a software problem ....how much period its after u have purchased this camera???????/
Jan 02, 2008 | Panasonic Lumix DMC-LZ3 Digital Camera
Aiptek ISDV2.4
When you say "turns itself off" do you mean the camera actually shuts off or does it just stop recording. If it just stops recording, it's because 10 seconds of video is all that will fit on the internal memory. If this is the case you just need to get a memory card for the camera.
If it's actually shutting off the power, there may be a problem with the camera. You could try posting about this problem at http://forums.steves-digicams.com/forums/view_forum.php?id=92
There are people there with a good amount of experience with these cameras.
Dec 30, 2007 | Aiptek IS-DV2 Camcorder
Memory Card Protected
On the memory card itself there is grey slider. Make sure it is NOT in the lock position.
Jan 26, 2007 | Panasonic Lumix DMC-LC70 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
148 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
