SOURCE: GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
SOURCE: Is there a water resivior/catch under the TFR22PR refridgerator?
towards the bottom inside the fridge, you will find a gulley with a drain in the middle. this drain is blocked. push something flexible down the drain till water flows away freely
SOURCE: Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
SOURCE: bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
I hope that this has been verry helpfull for you
best regards michael
SOURCE: water collection in fridge
.you need to check the drain to make sure it is not clogged or blocked that would stop the water defrosted from you evaporator coil from draining into the drain pan.rare occasions the unit will stay in a defrost mode while trying to cool causing alot more water to be draining.good luck with your fridge.let me know how things go for you.
