Cant get the maxtor 80g hard drive to connect with my pc
  • 22 Answers
TAKE IT OUT AND RE-INSTALL IT.CHECK THE JUMPERS AND MAKE SHURE THEY ARE SET TO MASTER OR FACTORY SETTINGS.LOOK AT THE JUMPERS ON THE OLD HARD DRIVE THAT YOU ARE REPLACING AND SET THEM EXACTLY AS THAT DRIVE.CHECK ALL CONNECTORS AND RIBBONS FOR SOLID CONNECTIONS.SOMETIMES,THE PINS INSIDE THE HARDDRIVE CONNECTOR BEND SLIGHTLY.IT IS REALLY HARD TO TELL UNLESS YOU REALLY LOOK AT THEM CAREFULLY.
Posted on Aug 22, 2008
Board is not recognizing my 80G Maxtor drive. I
with AmiBios you may be able to get it to rediscover your drive... If that doesn't work, open the case and check your IDE and SATA connections. Sounds like you have a RAID configuration with your Promise board.
Not sure I've helped, but you have some clues to check on. Probably visiting Promise's website and looking for troubleshooting may help.
If your Maxtor drive is a SMART drive, you might be able to check to see if it indeed has failed.
Feb 08, 2010 | MSI K8T Neo-FSR Motherboard
Can't retreive any info from my maxator green
Good day sir/maam, I had the same problem with my generic external drive, keeps blinking but cant be recognized by the PC. chances are the Maxtor is done, you can salvage the Hard disk inside. Visit your dealer if its under warantee demand for a replacement they may also have service people to take a look at the drive. hope this helps
Aug 03, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Can't reconize maxtor basic
Here is the support website for the Maxtor....>
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=DiscWizard&vgnextoid=d9fd4a3cdde5c010VgnVCM100000dd04090aRCRD
You will find drivers and things here....
Jul 01, 2009 | Maxtor BASICS Personal Storage 3200...
80G external drive claims to have only 14G free when empty
you will have to format your external drive again, using NTFS file system, and also check & connect your drive with some other pc's....
good luck
shafky
Jun 26, 2009 | Computers & Internet
Maxtor 80G won't work with ACER Inspire One notebook useing linus
Here is the support section for Maxtor:
http://www.seagate.com/www/en-us/support/downloads/
Seagate acquired Maxtor a few years ago and is handling all support on Maxtor products.
Dec 27, 2008 | Maxtor Hard Drive
Compaq d540s hard disk upgrade
Jackwan -
Sounds like the boot record of the drive may be corrupt. When you runs the XP installation, you'll be given an option to start the Recovery Console. Go ahead and open that, should bring up a command prompt. At the prompt, type "fix mbr" (With the quotes removed). Select Yes or Continue when asked, and go through the repair process, then reboot the system and try installing Windows again.
*Note*
You might want to check first, make sure the jumpers on the hard drive are set to Master, or Cable Select, and make sure the drive is connected as Drive 0 on the Primary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | HP Compaq d530S PC Desktop
Problem maxtor hard drive
What type of Computer are you installing this 80g drive on? How old is it? I need to know some specifics, because in older machines the BIOS are not setup to recognize large capacity HD, in addition you may have recieved a bad Drive. Please advise! I may have an answer for you!
Nov 26, 2007 | Maxtor Hard Drive
Hard drive instalation
To slave the Maxtor you remove the jumper or jumpers
Oct 30, 2007 | Maxtor Hard Drive
Computers & Internet Logo
David Payne
David Payne
