Sony ICF SW55 repair
The batteries in my SW55 leaked and since then it has not worked. I opened it and cleaned all the contacts and found out that the the the ribbon cable had corroded.
Is there a way I can get this radio fixed?
Thank you
C.
  • Anonymous Sep 07, 2008
    NED NEW ARIAL
  • Robert Gates Sep 14, 2008
    I have the same problem. Shipped it to Sony under their swap program but they didn't have one and said parts no longer existed to do a repair.
SOURCE:
SOURCE: Sony ICFM350S
I would like to know how to change the MW Tuning Interval from 9Mhz to 10Mhz.
The radio is a Sony ICF - M350S
Thank you
RM
Posted on Aug 27, 2008
SOURCE: I lost the user manual for my ICF-SW30 SONY radio.
tune to station you want preset; hold down Enter/Time button while you press the number you want the station to be on the keypad.
Posted on Jan 20, 2009
welcomejee
  • 10594 Answers
SOURCE: I need a manual for a Sony ICF-SW7600G radio
If you are looking for instruction manual, click Sony Support to download free copy.
Posted on Mar 30, 2009
kb8dns
  • 494 Answers
SOURCE: 13 years old Sony ICF-SW7600 not working
Sony radios of this era had notorious capacitor problems.... also several other brands were affected. These capacitors were underrated and the technology to make them was not at it's best back then. The cure is to replace the capacitors on the board with new electrolytics. About 28 of them need to be replaced but the big problem is to find someone to do this. the original capacitors are surface mount and must be removed and new radial lead caps put in their place, some are rather tough to get at and the new ones have to be placed carefully. My SONY ICF-SW7600 now works as new and maybe even better!
I have done this myself as I have skills working with surface mount capacitors. I offer my services to those who cannot find service for their radios. Please email me for details, I am not into making bucks on this, I just want to see these radios kept working and bringing enjoyment to their owners.
Good DXing Rod KB8DNS
Posted on Jun 15, 2009
SOURCE: my trusty sony icf 7700 got wet and needs repair.
Yes, Ebay UK user Merseyswimmer offers a specialist repair service for these and other Sony radios.
Posted on Jan 07, 2010
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
I own a sony icf sw 7600g short wave radio which worked perfectly until recently when I believe a battery may have leaked and now it is caput with nothing coming on ; dead dead ! is it fixable and can you...
When a battery leaks it leak acid which can damage or ruin everything it touches. First how extensive was the leak? Was it just a bit or did it seep onto the circuit board? You can clean the terminals. Remember your dealing with battery acid. Do it over a metal can and brush the terminals with a small wire brush. (Don't touch your eyes until your finished and have thoroughly washed your hands.) Just like you would a battery terminal. Then when down to the metal again use a regular pencil eraser to finish the cleaning. You may try a drop of flux per terminal as well after using the wire brush. If a wire was negated then soldier a new one in. You can also use a small, dry, non soap impregnated SOS pad in place of a wire brush. Install new batteries and give it a try. If no acid ruined the circuit board it is just an issue of getting the terminals to run current through them again.
Mar 07, 2011 | Sony ICF-SW7600 AM/FM/SW Radio
Sony ICF ICF 77 Receiver has intermittent Low Frequency distortion burst when tune exactly to the center of an FM frequency, say 102.5 mHz. When radio is tuned .5 mHz. + or - of the main channel frequency...
Usual problem of these receivers is faulty capacitors. Recommend replacement of all surface mount capacitors and alignment. Contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2011 | Sony ICF-SW77 AM/FM/SW Radio
Hello i got this radio in 2006 and last year the batteries leaked in it and I opened and cleaned it with rubbing alcohol and it worked fine till after few months it started to become slow like it would...
Corrosion can be deeper in the radio and cause all sorts of problems from rotting copper traces to messing up the keypad. Needs to be checked by a good technician and taken apart even more for cleaning and /or repair
Jan 14, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Need replacement antenna for ICF-SW55 radio
dear Sir, I need the battery compartmenr lid and tha antenne for sony icf sw 55. I hope you could help me with that..Waiting for your instructions..best regards.. tuncay bayer . bursa - turkey [email protected]
Nov 18, 2009 | Sony CDX-GT320 FM / AM / XM Radio / Sirius...
Hello, My SONY ICF-2010, SN 82502, has ceased to function...it cannot be powered up either by fresh batteries or the battery eliminators I have...no indication of life on the LCD display... I tried having...
http://www.eham.net/reviews/detail/479  says Over the years I've read that some 2010s were prone to static induced blowing of the front end transistor and that others had trouble with an unstable coherent AM detector. Thankfully my receiver was OK in both respects (I take care when touching the whip antenna in low-humidity environments)   that narrows down which part has likely failed
Nov 07, 2009 | Sony ICF-2010 AM/FM/SW Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF SW55 always OFF
I have the same radio.
It was given to me not working
I took it apart.
Was surprised about the contacts not being soldered
After re assembly and with new AA nicads it started.
First it would take clock and then go off
losing clock settings.
then it comes on and starts fro factory CAL menu.
after repeating many times now coming on with all functions
volume not great
sensitivity/signal strength good
Now after recharging batteries stays on and last longer.
It appears that resistance/poor contact with circuit board of battery connections causes l;oss of voltage.
Suggest follow these steps cleaning with solution and may be also re tensioning contact contact areas.
jmho
good luck
Mar 04, 2009 | Sony Audio Players & Recorders
LCD display invisible on Sony ICF-2010
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Mar 09, 2008 | Sony ICF-2010 AM/FM/SW Radio
1,125 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
