Question about iLO (2 GB) MP3 Player
MICRO SD HOW TO REMOVE WRITE PROTECTED USB DISK
  • 134 Answers
Click > Start > Run > type "CMD" Then
Type "CHKDSK" and type the letter of your SD drive and "/F".
chkdsk Q: /F > press Enter
another example:
chkdsk D: /f
chkdsk E: /f
D or E is the letter or your SD drive.
Posted on Apr 29, 2009
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My sandix 2gb microSD mameory card is write protected how will i remove it?
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 29, 2010 | SanDisk 2GB microSD Memory Card
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
My flash dik is write protected
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Sandisk micro SD
Check the adapters switch is in the unlocked position
May 04, 2010 | SanDisk 2GB microSD Memory Card
How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Apr 03, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Pny micro sd won't copy files
has the write protect been moved
Jun 26, 2009 | PNY 2GB microSD Memory Card
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Write protected
micro sd card have a little switch on the side, move the switch to its other position to enable disk-writing
Jan 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
iLO (2 GB) MP3 Player Logo
112 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
