Question about Copystar CS-2030 Copier
Error c710? my machice is a CS2030 whatt is? help me
    Problem Solver:
  • 8 Answers
Double check the connector for image process unit (Drum/DV) White connector to the left when you open front cover. Error code is a toner density sensor prob, could just be that connector isnt plugged in right. power down before reconnecting!
Posted on Oct 10, 2008
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Troubleshooting a Copystar CG1505 with an error code of C710.
C710 Toner sensor problem
Try removing and refitting drum and toner.
If that doesn't help the toner cartridge or sensor is damaged.
Please take a moment to accept and rate this solution accordingly.
Thanks,
Lee
Sep 26, 2008 | Copystar Office Equipment & Supplies
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Mita Kyocera KM1535 with an error code. C710
C170-Toner sensor/Developer Error
check usual suspects Sensor, Wiring, Developer material, connectors.......
Feb 05, 2009 | ASUS P5GZ-MX Motherboard
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
May 27, 2008 | Office Equipment & Supplies
C710 Code on Copystar 2030
if this does not help you may have damaged your toner cartridge or the sensor
Feb 20, 2008 | Copystar CS-2030 Copier
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Feb 15, 2008 | Copystar CS-2030 Copier
Copystar CS-2030 Copier Logo
184 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
