Compaq Deskpro EN - How do you remove the harddrive? It slides back just so far and then firmly stops.
    Scholar:
  • 152 Answers
There 'should' be screws that hold the hard drive in place, usually, 4 of them. Have you removed all of the screws? Is there some other impediment that is preventing the drive from being removed? Post back and let us know.
Posted on Aug 22, 2008
Compaq deskpro en case opening
Look at the back of the computer. One side panel removes. (Access Panel) There are two Thumbscrews to loosen on the Access Panel, then the panel is lifted off, or brought straight out.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=135&prodTypeId=12454&prodSeriesId=96266#2
On this HP Support page click on -
Deskpro EN Series of Personal Computers Maintenance and Service Guide
Regards,
joecoolvette
Jan 20, 2012 | Compaq Deskpro EN PC Desktop
The comp is experiencing booting problems
Open the back cover of cpu cabinet. Then reconnect RAM memory and both connection to harddrive . Pull cmos cell from motherboard for 10 minutes then put it back reconnect all connection to motherboard and ATX connector, make sure RAM is working fine and harddrive recognized in bios . Make sure motherboard doesnot ground with cabinet. Reconnect pci card if any. Let me know if you need further assistance. Thanks for using FixYa.
Sep 22, 2011 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
How can i speed up my compaq deskpro en?
Try to upgrade your RAM 256 to 512MB or 1Gig.and try to change your harddrive to 20G to 40G or 80G.
Sep 13, 2011 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Compaq Deskpro EN 1GHz. power supply is ok. But not start with power on button. Green LED on mother board is on. How can I start this with start button (I think motherboard board problem.
Unplug it from the wall. Remove the side panel. Look for a small circular battery (similar to watch battery). Remove the battery for 30 seconds. Replace the battery, plug it back in. This should reset the bios. Green light on the board does not necessarily say good power supply as well. Very likely motherboard or power supply.
Dec 11, 2010 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
How to remove the top cover of compaq deskpro p3?
Press both tabs on the front plastic of the case, and pull in forwards. You can then lift the top off.
To replace, sit on, slightly forwards, and bang backwards with force.
Oct 19, 2010 | Compaq Deskpro EN PC Desktop
Have old compaq Deskpro EN ENS815EC733 M1BU
I would buy a cheap usb card to fit into a pci slot on the old computer.
Otherwise you would need a serial cable (if your laptop has a serial port) if not it would be a serial to usb plus the software to transfer, i would say far too much trouble.
A usb card is a couple £/$
http://www.google.co.uk/products/catalog?hl=en&q=pci+usb+port+card&um=1&ie=UTF-8&cid=13689229979239224585&ei=5RBCTMCBCIyOjAfu8eUV&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CDAQ8wIwAg#
Jul 17, 2010 | Compaq Deskpro EN FC 6450+ Model 10000...
Compaq deskpro en pentium iii no video
Sounds like the video card has quit. It may also have onboard video. I would try a new video card or try onboard video (if equipped). Good Luck
Nov 23, 2009 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Compaq deskpro EN
mi compaq deskpro pentium iii enciende y se queda contando la cantidad de memoria..y luego se reinicia..y cuando le doy a f10 me dice que el cmso tiene problemas, y le he quitado la pila y el jumper pero todavia sige igual, y le he dado al boton que esta en el board que dice CMSO , pero no se arregla nada
Sep 26, 2009 | Compaq Deskpro EN PC Desktop
UPGRADING FROM PENTIUM 3 PROCESSOR TO PENTIUM 4 PROCESSOR
To upgrade from a Pentium 3 to a Pentium 4 processor, you would have to replace the motherboard. The Pentium 4 processor has more pins on it than the Pentium 3 and would not sit in a Pentium 3 motherboard.
Apr 05, 2009 | Compaq Deskpro EN PC Desktop
Red blinking light when on my compaq deskpro en pc
Probably your power supply. They are pretty cheap to replace. If it's plugged into a power bar then try plugging it directly into a wall socket just to make sure it isn't your power supply.
Apr 01, 2009 | Compaq Deskpro EN 6350 Model 4300...
Computers & Internet Logo
David Payne
David Payne
