Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
No cooling at all
The lights come on. The condenser fan runs as well as the inside fan, but there is no cooling and the compressor is not running. I looked for a defrost control, but cannot locate it. The number on the back is GSS25LGMF. I also tried unplugging it for a while then plugging it back in in case something might need to reset.
  • MARTIN BAUMHOFF Aug 24, 2008
    I unplugged the orange and white wires from a small box near the compressor and connected my voltmeter to them. When I plugged the power cord in the compressor kicked on and there was voltage on the two wires that I disconnected. Just to be sure I unplugged the power cord and reconnected the two wires to the black box, which I am assuming is the relay overload, and plugged the power cord back in. The compressor did not come on. I think my problem is solved. Thank you very much.
    Scholar:
  • 149 Answers
I'm suspecting a defective relay/overload on the compressor
to test remove the rear cover, the locate the compressor there should be two wires to it (with power off disconnect them)after that, hook them to the voltmeter leads and carefully plug in the fridge make sure the wires don't touch and verify if you have voltage if so, relay overload is defective after changing and unit still won't power it's the compressor. hope to be of some assistance also on the main board theres a high voltage side you can check voltage from L1 and comp terminal (i think that what there labled, i worked on one some time back) there should be 120 there if not suspect a faulty board , contact if you need more info i could send you a service manual in pdf that i have that could assist you. e-mail's hvac.tech7872pr@gmail.com
Posted on Aug 23, 2008
  • Alexander  Figueroa
    Alexander Figueroa Aug 25, 2008
    i'm happy that the adviced worked!!
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
Ge profile 26 pfss6pkx Light comes on but won't get cold, no fan running
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 15, 2014 | GE Profile PFSS6SMXSS 26 French Door...
Fridge stopped working light on motor not running
Robert,
Need more info. I am unaware of a "light on the motor". There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. Normally none of these have a light. If you are referring to the light inside the box that turns on with opening the door AND the frig is not cooling, we must go to the very start. 1. Verify power at outlet.
2. Do you see (or inside the box- hear) the two fans running. 3. Is the compressor smoothly vibrating?
Oct 12, 2013 | Smeg FR158SE 1 Compact Refrigerator
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
No cooling in fridge or freezer. Unit has power - light goes on.
Hi greenhouse76,
Please check if the compressor is running. If it is running and the machine is not blowing cold air inside the freezer. You may have either a restriction inside the sealed system or have a leak in the sealed system and all the Freon has escaped. No Freon, No Cool. Not a DIY job.
In order for the machine to get cold at all, the motor has to run. If the condenser fan (fan by the compressor) is running and the compressor is not running then you have one of a few problems. Either the motor is not getting power and that's why its not running, or its getting power and the windings inside are shot and that's why it's not coming on.
When the condenser fan is running you need to check to see if voltage is getting to the relays on the side of the Comp. More often then not, these are the parts that go bad. First Check for voltage to the relays and see it they have 120 Volts AC. If so, check the pins on the compressor that the relays connect to. From this point you are going to need to remove Compressor Relay Cover the clip that holds the relay to the side of the compressor, then unplug them from it and take them off.
Hope it helps.
Thank you for using FixYa.
Jul 06, 2011 | Magic Chef Refrigerators
I am a different person with the same problem the compressor kicks on ,the light is on but it doesnt get cold it does seem like the fan at the top isnt working the one in the middle is thank you
The compressor is running, that is a good sign. If you notice any cooling that is not a good sign. Even with the fan not running , the evaporator should have produce some cooling. Could it be that you are a condenser fan running? well, the compressor makes a distinct sound when it runs and you need to confirm that is running and not just the condenser fan.
Firstly- If you confirm that the condenser fan is running; that is, if there is one, that is good. Secondly- Check and confirm that the compressor is running Thirdly- If there is an evaporator fan inside the unit, check and confirm that is running.
If all checks okay and there is no cooling, the refrigerant might have escaped through a leak, and there will not be any cooling. You can extrapolate from my troubleshooting steps to diagnose the wine cooler problem.
Good luck
Appliancewiz
Jacques
Dec 27, 2010 | Danby DWC257BL Wine Cooler
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Sky box--soda fridge--compresser not running -fan on the inside running
what about the condenser fan.? is it running?...that is the fan near the compressor.
if it is not running, then it could be the thermostat. the part that controls the cooling including the compressor and the condenser fan, please check it.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Maytag Refrigerators
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
201 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
