Question about Lexmark Office Equipment & Supplies
Me x9350 onley prints in black put ne color and black car. in it and its te
  • 48 Answers
Try doing a print head cleaning
refer to your user's manual for step by step instructions..
Posted on Aug 22, 2008
I have a hp 3310 wireless. It prints in colour well but if you print in black most will be not clear although a line every so often is printed clearly. If you print the same document the same lines...
What you are trying to print is created in RGB. This means it is a photo that has been created in a color format that will ONLY print if you print it in full color. If you try to print your photo item in only black, it will only print what it sees in TV Colors, a combination of RED GREEN BLUE. This is why you will only get part of the image printed when only in black.
The only way to change it to print the whole image in all black, is to open the image you are trying to print in Photoshop or another professional grade photo program, and to change the settings of the image to CMYK, effectively, Cyan, Magenta, Yellow, Black. Then, change the image once again - to GREYSCALE. This will effectively change all the colors to a SHADE OF GREY, in different HUES.
Save the picture as a JPEG, and then print from the desktop, from your picture viewing software that came with your computer, and you will see everything print out from the black ink, in greyscale.
Nov 16, 2010 | HP Photosmart 3310 Printer
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
Jan 17, 2010 | Casio FX-250HC Calculator
I want to order the TwinPack of #43XL and #44XL, Black and Color Print Cartridges. I get a graphic for it but no way of choosing it (no add to cart)
That must be an error in the website developer. Odd to say the least.
You have a couple options:
1) Call 1-800-LEXMARK (539-6275) for order help. I am sure they will be able to get you your request. Explain to them the problem and hopefully they will correct it. Mention Part#: 18Y0372.
2) Try another vendor, such as Staples.com, Buy.com, officedepot.com, or inkjetsuperstore.com.
Thanks for using Fixya.
Nov 21, 2009 | Lexmark X9350 Printer
Wont print color will print from black cartridge only both are ne
Try <CTRL> P
Find the color option:
Make sure that you are not printing in gray scale:
Oct 05, 2009 | Lexmark Z611 InkJet Photo Printer
Hello, I want my printer to print only in black. How do I make it do this permanently. Thanks
Well you can do this in the print setup under te color option but you must have color cartridges present anyhow its just the way the system mixes. It ca nbe done tho trust me. But you do want to have color in there because the printer will not go without it. when the black ink runs out it uses color to mix.
Sep 22, 2009 | Lexmark X4650 InkJet Printer
Lexmark x9350 won't recognize new cartridges
hmmm this s the prb in u r printer settings...u jus give a print test after fixing the new cartridges...then if it works then there no prb in cartridges...or else there s dust in the printing rod...u jus want to giv the printer for service so that they will clean the motor of the printer and u r printer s set for working...cool!!!!
Jul 25, 2009 | Lexmark X9350 All-In-One InkJet Printer
My HP PSC 950 printer copies and scans in color but prints in black
normally when the color tank runs out 2 things happen.
1] not all the colors run out at the same time.
2] the printer complains the tank needs to ne replaced.
If the tank isn't dry, it could simply be clogged. I like to use rubbing alcohol or distilled water and a cotton swab.
Dip the swab, & then gently apply pressure in the nozzles.
I would expect to see the clog before the cleaning process, some color to come off & when pressed on a paper towel, hopefully 3 bands.
Jul 05, 2008 | HP PSC 950 All-In-One InkJet Printer
: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
