Question about EliteGroup L7VMM2 Motherboard
NO VEDIO THE MONITOR IS BLACK
THE MONITOR WILL NOT START
  • esginme207 Aug 22, 2008
    have a emachine mother board L7vmm2 no monotir display at all .
    Master:
  • 623 Answers
Tv troubleshooting site
http://www.epanorama.net/circuits/vga2tv/vgatv_troubleshoot.html
Posted on Aug 22, 2008
  • 6,487 Answers
Check if the cable is connected properly from the video card, IF still the same problem, unplug/replug the video card from its slot ten try it again...
Hope that helps.........
Sometime screen not still pixel viberation
this problem can happen if the vedio cable is loose or bad. take the the back off panel get the vedio cable make sure its pluged in tight if it is and you still have the problem price and consider replacing the cable
Dec 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
I got a black and white signal (picture ) also it is very weak , i have to increase the brightness to be able to see the black and white screen , when i turn it on some times after 5 or 10 or30 minutes it...
it usual problem with LG monitors. u can fix it just by soldering vedio board epecially vedio ic affixed on crt. bt do it gently becoz any bridging of solder may damage ur microcontroller.
Sep 07, 2010 | LG Flatron F700B 17" CRT Monitor
I have a black screen with a slow blinking green power button. I checked the connections they are good. I have another monitor that works fine with the same computer, and cable.
Please check your screen resolution the best resolution is 1024 x 768 on xp or if ur vedio card supports set it on 1260 x 768 for the display setting.
Mar 30, 2010 | Dell E173FPb 17" TFT LCD Monitor
My display don't have light
Disconnect the unit from the computer.
Disconnect from power source.
Let the unit sit for a few minutes.
Plug the unit into the power outlet.
Push in the power button and if you get a message on the screen that says " No Signal " The monitor works fine.
Next, plug the unit into the computer port.
If you do not see a image or a signal, you may need to reseat the vedio card inside the computer.
Sep 25, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
My monitor won't work the power button flashes on and off and my screen stays blank and it just sits there with the power button flashing on and off repeatedly
ITs the Vedio card issue, the power on your screen is on but the image is not there coz the vedio card is not shooting any picture, check the vedio card connection, the one comes from computer to screen , make sure is well connected and on the right place, if it doesnot work, open the computer and make sure your vedio card is pluged well and not out of place, if all this doesnot work change ur network card. but before that when u put ur pc on did u hear any beeps? if yeah let me know how many beeps you hear and if its short or long so i can help you. Regards
Jun 14, 2009 | CTX S762A 17" LCD Monitor
Picture on monitor will get big then go back to normal
check your windows monitar setting, if it has no problem! update your vedio card driver, if non work u have problem in your vedio card. change it.
Mar 01, 2009 | Dell Dimension 2400 PC Desktop
No signal msg on the monitor
you have to check:
1) the monitor work ok itself with other PC. (or change a monitor test better
2) open your PC cover look power on work status, power supply work and all fans sunning, then go next
3) change the RAM first slot memory still no msg go next
4) find out any vedio card used (AGP) , and looking for any vedio build-in the motherboard, you may change the monitor sigbal vable
one to another VGA interface,
Dec 26, 2008 | ASUS K8N Motherboard
Viewsonic Monitor black screen but when turned off and then on-the screen will come up for a couple seconds and then go away
this problem have 2 posiibilities
1)solder lose on the vedio socket and around horizental circuit
2) the line
and mostly in viewsonic and compaq its the line wich you need to replace it if you can find it in the market
Oct 30, 2008 | ViewSonic Computers & Internet
Monitor blinking
Try replacing another CRT to verify whether this prob is related with the Vedio card or not. Then.... the result will coming.
Jul 29, 2007 | HP Compaq FS7600e CRT Monitor
EliteGroup L7VMM2 Motherboard Logo
119 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Matthew Spark
Matthew Spark
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
