SOURCE: what the air pressure in front tires on a cub
check the side of the tires . it will tell you. szm230
SOURCE: i have the suncast model
The hose on the side that connects to the water supply is not the same hose that goes inside.
The side hose connects to the faucet and the fitting on the hose reel is not supposed to rotate.
The hose that the homeowner installs connects to the adapter on the center of the reel and this goes around when the spool is turning. Beyond that, I don't really understand the question. Hopefully this will give you some information that you can use and then post back.
Gary
SOURCE: hose reel. I can't figure
It is a type of quick connect adapter....it would be helpful if you could find out what brand....
Here is one type
Most either have a quick slide feature where you pull back on the one side and then pull apart the connection, or they simply push together and twist to connect...
heatman101
SOURCE: Took off back tire to
Are you sure that it is not going into gear? Could it be that the key did not get put back in place. The key is a little rectangular piece of metal that slides into a slot on the axle and inside the center of the wheel to keep the axle and wheel interlocked. Sometimes they slide out when putting the wheel back on.
Rankam's BBQ Grills & Accessories
1322 Rankin Drive
Troy, MI 48083
888 837 1380
But, don't waist any time, as your grill only has a 90 day warranty.
Add a Commentry flat tire
Try flat tire,fix leaks.
You should not leave cart in fix position . This causes tire to dry rot
