Question about Kenmore Elite HE4 Electric Dryer
Back panel removal
How do I remove the back panel to vacuum out lint that has accumulated in the dryer? It seems to be welded on.
  • jseltzer Aug 25, 2008
    That was awesome advice. Thanks a lot!
  • 1,028 Answers
It is..remove bottom panel ..after unplugging from wall..remove lint screen next remove 3 screws holding the lint screen/blower housing in place ..clean out housing clean blower wheel with long brush or a long arm clean lint from base and on element housing on right side especially on top of the housing..that is the most important location if lint gets too thick on element housing hazard....ckd vent behind dryer and to outside if you find a large amount of lint .that is good indication of a restricted vent
Posted on Aug 22, 2008
How do you remove back panel on Kenmore gas dryer model 97591240 75912? seems to be tack welded?
If lint filter is in door, back doesn't come off. Top and front comes off in that order.
Sep 18, 2017 | Kenmore Dryers
Rattle vibration
Dryers do what they are designed to do, Dry things. In the process everything inside the drying cylinder makes dust and airborne particulates called Lint. The Biggest bane for dryers is Lint accumulation. Clean the Lint filter screen. If it detaches from the dryer housing with screws remove them. Clean out what you see if you have a wet vacuum with a small hose carefully push this down into the opening and vacuum it ou. Another thing pull your dryer out from the wall disconnect the power and remove the vent hose. Vacuum inside the opening in the back of the dryer. You would be surprised how much lint accummulates here. Lastly check your vent hose for lint accumulation or blockage. If you find it blocked, disconnect the hose from the vent going outside and clean it all out with a vacuum . Put it all back together and run a load of clothes if you dont see a marked improvement in circulation and drying time, then either the blower fan is n't working properly or you have a burned out thermostat. If you have heat flowing turn it up to max heat and see how hot it really gets if on opening the dryer you feel extreme heat then it is either working right or the thermostat is not shutting off at the high limit. the Thermostat is a piece of Bimetallic metal that is extremely sensitive to certain temperatures. When they reach the preset heat limit they shut off allowing the heating elements not to burn out. A good investment is to keep dryer maintenance at regular intervals. They sell dryer cleaning brushes and Vacuum hose attachments for getting into the deep crevasses and nether regions of your dryer. Good luck and happy drying
Apr 06, 2014 | Roper Dryers
How to clean debris below lint filter Frigidaire Gallery GLER341as1
Pull the exhuast vent off the back of the dryer, remove the lint screen and then turn it on for a few, should just blow out the back.
Jan 09, 2013 | Dryers
Dryer works only on high heat; will not respond to touch pad.
Replace the gas valve coils. They have gotten weak and do not open on the next call for heat.
Aug 30, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
How to remove the back
Dryer back does not come off, the screws removed secure parts to the inside of the case.
put them back before anything detaches.
the front panel comes off
  • pull wall plug
  • remove lint screen
  • remove 2 screws in housing under lint screen
  • with putty knife or other blunt blade in gap between top and front,
    depress spring catches at both corners of top panel front, tilt up top
  • remove 1screw each side 1/3 down front panel
  • remove door swicth wires
  • tilt front panel down and remove
all internal parts are accessible
perform repair
examine rear of case from inside and refit anything detached by screw removal
reassemble in reverse order
Oct 20, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer
You need to check the dryer INTERIOR to ensure there's no lint accumulations on or around the heating element. The exhaust systems on dryers are not perfect and SOME lint often gets by the lint screen and can start the collect inside the dryer. The lint will begin to smolder and give off an odor if it sits on the heating element housing. Make sure the dryer is unplugged before attempting to access the interior. If the model number you provided is correct, the heating element will be located under the drum on the right-hand side. You will need to lift the dryer top and remove the front panel (with the door) to access the inside and vacuum. Let me know if you need further assistance. I hope this information is helpful to you.
May 08, 2008 | Whirlpool LER5636P Electric Dryer
LG Dryer cracked drum on Model DLE5977W
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Apr 28, 2008 | Dryers
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How...
not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Apr 26, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
272 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
