How to reset BD DIGITAL THERMOMETERHow to reset BD DIGITAL THERMOMETER
AnonymousMar 25, 2014
how to replace battery in BD digital thermometer. I got the end cap off but battery won't releasehow to replace battery in BD digital thermometer. I got the end cap off but battery won't release
You can't post conmments that contain an email address.
The sensor is sensing a temperature that is lower than the lowest possible temperature that can be displayed on the thermometer. If it is actually warm then the sensor has failed
I just had that LO reading. Pulled back on the tip of the thermometer. Seems I had it inserted into my turkey too far. Probably up against a bone or too close to the center. Good luck! Happy Thanksgiving 2016!
there should be a setting on it that changes the temp from Celsius or "c" to ferinheight and lo means that it currently isn't reading a temperature in the normal range. try running it under hot water and see if it says error or high.
If you whish to switch from Celsius to Fahrenheit, proceed as follows:
(1) Make sure the thermometer is turned off.
(2) Press and hold down the Start button (IRT 4020) or the «I/O» button (IRT 4520). After about 3 seconds the display will show this sequence: «°F» / «SET» / «°C» / «SET» ...
(3) Release the Start button / «I/O» button when the desired temperature scale is shown. There will be a short beep to confirm the new setting, then the thermometer is turned off automatically.
Changing the temperature scale
Your Braun ThermoScan is shipped with the
Fahrenheit (°F) temperature scale activated. If you
whish to switch to Celsius (°C) and/or back from
