Windows media center has "stopped " working. The only message I get is " COM Surrogate has stopped working
    Problem Solver:
  • 5 Answers
If you've been getting the error COM Surrogate has stopped working whenever you browse folders containing video or media files, you have come to a good place for some possible solutions. This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
Here's the error message:
There are a number of possible solutions to this problem, and the right solution depends greatly on what software is actually causing the problem. Some of the most well-known problem causing softwares are DivX and Nero, but there are others that cause the problem as well.
Possible Solutions
  • If you are using DivX, you should be upgraded to the very latest version (6.5+)
  • If you are using Nero, you can try upgrading to the latest version (7.7.5.1+)
  • If you’ve upgraded Nero and Divx and still have the problem, you can try renaming the file C:\Program Files\Common Files\Ahead\DSFilter\NeVideo.ax to NeVideo.ax.bak. You may also need to rename NeVideoHD.ax to NeVideoHD.bak
    This will break Nero Showtime, however. (thanks to dugi in the comments for this one)
  • You can disable Thumbnail previews, which should make the problem go away, but isn't the optimal solution.
  • The older ffdshow codec pack has been known to cause some problems. The ffdshow tryouts codec pack seems to work better. Might want to try using this one: http://ffdshow-tryout.sourceforge.net/
  • If you'd like to uninstall Nero entirely, there is a utility that they provide to help with complete uninstall that helps a lot in instances where you have a bad installation of an older version. http://www.nero.com/nero7/eng/FAQs_Nero7_NeroVision.html
  • Some users have recommended installing the Vista Codec Package in order to update all your codecs to the correct versions. I can't confirm that this works because I have not tried it myself. As always, be careful when installing unknown components and create a restore point.
  • You can use the very useful MMCompView free utility from Nirsoft to disable any codecs on the system. This is very useful to help troubleshoot exactly which component is causing the problem.
  • There's another possible solution below of turning off DEP for dllhost, which might not work for everybody. You may have to add divx+nero executables to the DEP ignore list.
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate) can fix this problem for some people. This solution is detailed below.
Right click on Computer, and choose Properties
Click on Advanced System Settings, and then under Advanced, click Settwindows media center has "stopped - clip_image00211.jpgc="http://i.fixya.net/uploads/images/clip_image00211.jpg" alt="clip_image00211.jpg" class="h_mi" />
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and swindows media center has "stopped - clip_image00221.jpge I select�
clip_image00221.jpgwindows media center has "stopped - clip_image00231.jpgbutton, and then browse to C:\Windows\System32\dllhost.exe as shown
Click Open, and then OK.
Here's what you should see&helliwindows media center has "stopped - clip_image00251.jpg"http://i.fixya.net/uploads/images/clip_image00241.jpg" alt="clip_image00241.jpg" class="h_mi" /> Now you can browse video folders without problems!
Posted on Aug 22, 2008
If I diable com surrogate will it harm my computer
Com surrogate is a service that allows switching on the com ports. Without it, communication to your devices will stop. If you're encountering this error there is a driver problem with your com port controller and you need to install the correct drivers.
Sep 01, 2014 | Microsoft Windows Vista Home Premium...
''COM surrogate has stopped working.................
Sir COM means "Component Object Model". These are basically DLL files which are used for system tasks and if they get corrupted then you get same problem. For solving this you need to repaid your windows using windows disk.
Jul 21, 2009 | HP Computers & Internet
Com surrogate has stopped working.
find the link for the software u need on this website http://vistatipsforall.blogspot.com/2007/05/com-surrogate-has-stopped-working-error.html
May 31, 2009 | HP Computers & Internet
Com surrogate
These should help:
http://www.howtogeek.com/howto/windows-vista/fix-for-com-surrogate-has-stopped-working-error-in-vista/
http://www.superbdevelopment.com/forums/general-tech-talk/3600-windows-vista-com-surrogate-has-stopped-working-fix-solution.html
http://www.mydigitallife.info/2008/06/13/how-to-fix-com-surrogate-problem-when-opening-video-format-files/comment-page-1/
Error message: "COM Surrogate has stopped working."
COM objects are often defined in Dynamic Link Libraries (DLL files). The Program file for COM Surrogate is actually dllhost.exe that can load a DLL and make its objects available to other programs.
The COM Surrogate error message is often related to codecs and other COM objects that aren't fully compatible with Vista. These are installed by other programs. The most common culprits are DivX and Nero. The first thing you should do is upgrade to the latest versions of these to see if that fixes the problem. Another possible fix is to disable thumbnail previews in Explorer. To do that:
In Windows Explorer, click Organize, then select Folder and Search Options
Click the View tab
Check the box that says "Always show icons, never thumbnails"
Click OK
To help troubleshoot which codec(s) might be causing the problem, you can use a free tool called InstalledCodec. You can use it to disable individual codecs one at a time.
You can download it at http://www.nirsoft.net/utils/installed_codec.html
Hope that helps
Mike
May 13, 2009 | Dell Inspiron 1521 Laptop
The desctop is locked
COM Surrogate errors The Component Object Model (COM) is a platform for developing software components developed by Microsoft and commonly used on operating systems such as Windows Vista, Windows XP or Windows 2003 Server. COM has been known under many names over the last few years including OLE, ActiveX, DCOM and COM+. Essentially it is designed to allow for easy re-use of software.
So what are these errors? COM Surrogate errors can occur when something wrong happens when software uses in-process components outside the main process either on the same machine or on a remote server. The default DLL surrogate (Dllhost.exe) can act as a host for in-process components. This is often used on Windows Vista, XP or Windows Server 2003.
According to Microsoft
"The file Dllhost.exe is an executable component that you can run remotely and instruct to load any in-process component, providing the component with a surrogate parent process and security context."
How to help fix this? Usually some software is out of date on your PC. You could try updating your software components. You might try updating software like Nero or DivX as this often happens with media software players for video files, music or MP3s. Other people have reported success by using QuickTime or Real as an alternative to using the software that caused the previous errors. Here is what you need!!! Click on the Above Link. Follow Each and Every Step!!!
Hope This Helps!!! Please Rate my Response!!! Thanks!!!
ROGER
Mar 13, 2009 | Microsoft Windows XP Home Edition
http://fileforum.betanews.com/detail/Vista-Codec-Package/1159994557/1
Just download this small program and everything should be just fine . I was having the same problem , ive been told that its because of nero or divx codecs , didnt unistalled anything just installed this program and my problem was solve !
Nov 28, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
Com surrogate and run ddl 32 problem
download codec pack and install it, ex - k-lite codec pack its free on net
Nov 11, 2008 | Microsoft Windows Vista Ultimate Edition
Software problem
Hey there
You get an error message that COM Surrogate has stopped working whenever you browse folders containing video or media files, This problem is caused because of codecs and other COM components installed by various softwares that aren't fully Vista-compatible, like some versions of DivX or Nero.
Essentially, turning off Data Execution Prevention on dllhost (the COM surrogate) can fix this problem . This solution is detailed below.
Click on Advanced System Settings, and then under Advanced, click Settings
Select the "Data Execution Protection" tab, and then click “Turn on DEP for all programs and services except those I select”
Click on the Add button, and then browse to C:\Windows\System32\dllhost.exe as shown
Here's what you should see…
Gimme your Acknowledge by rating me
thanx
Romy
Jul 31, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
