Question about Whirlpool Washing Machines
There is a noise (hum) when the spin is set. No spin.
    Genius:
  • 1,028 Answers
Probably pump plugged if that is a front load remove bottom panel pump has a clean out port clean thoroughly and retry is still only hum pump impeller may be jammed or damaged ..removing pump will allow better acess to impeller area
Posted on Aug 22, 2008
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My kenmore dryer makes a humming noise when u turn it on n the drum will not spin
If you are hearing a humming noise and no spinning . You have a burnt motor..Do not attempt to switch it on till you fix it to prevent further damage
Mar 07, 2011 | Dryers
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Water won't drain out of my washer nor will the spin work. There is just a humming noise if i set it on spin...
The humming noise you can hear is probably the pump trying to go.
It is probably blocked, or the filter needs cleaning..
You need locate and clean the filter, usually at the bottom front of washer.
Jan 08, 2010 | Whirlpool Washing Machines
I have a whirlpool washer and it will not spin
The problem will be in the main board or the spinning coil may be short circuited, You can easily check the motor during the spinning process you will find the humming noise if you do not found any humming noise kindly replace the board
Dec 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryer won't spin
hey first make sure the timer knob is set on drying cycle and not off ( know it might sound stupid but people forget sometimes) and if its making that noise the humming it means you need a new motor 100% sure its not easy to do if you have never done it before
Jun 07, 2009 | Frigidaire Dryers
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal De
