Question about Compaq Armada E500 Notebook
Compaq armada e500 boot up
When I power on the laptop it acts as if it is going to boot up normally. I get the Compaq screen 1st, then initializing intel boot agent version 2.6 screen, then it goes to the microsoft logo windows xp screen. It continues to do this in a never ending cycle. I have tried booting in safe mode but nothing gets me past the windows xp screen.
  • Anonymous Sep 07, 2008
    armada e500
  • Compaq Master
  • 5,568 Answers
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there which will prevent the continuation of the unsuccessful boot routine. If you can reach the Safe Mode, run Restore and go back to an earlier point in time, you may have to go back several times because if you have picked up some kind of malware, it may have been backed up with everything else.  Unless it is a really smart bug, you might be able to circumvent it.
Posted on Oct 11, 2008
Boot usb on compaq armada E500
At boot enter Boot Menu, select USB. Or , boot to BIOS and select USB boot.
Feb 02, 2013 | Compaq Armada E500 Notebook
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
May 13, 2010 | Compaq Armada E500 Notebook
Armada e500, enter bios, how to?
While the laptop is booting press continuously the f2, f8 and Delete key, until the bios screen or a prompt screen shows up.
Oct 13, 2009 | Compaq Armada E500 Notebook
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Booting problem
You need to do power drain
step1. remove battery and ac adapter from your laptop
step2. HoLD POWER BUTTON for 30secs-1mint
step3. put back battery and ac adapter
step4. power on it sud boot normally
try this hope it helps you
Feb 25, 2009 | Compaq Armada E500 Notebook
Display problems
Hi,Have you installed new RAM recently?if so it might not be properly seated,it's worth reseating it and see if that helps,or try removing RAM sticks alternately it may be a faulty one.
Dec 22, 2008 | Compaq Armada E500 Notebook
Compaq armada e500
The key for bios is F10 just press during compag loading screen or if dat doesnt work immeditely after. I found this out by trying all of them in sequence to see which one worked
Jun 09, 2008 | Compaq Armada E500 Notebook
How do i unlock my compaq armada e500?
I JUST LET IT SET AND IT FINALLY SHUT DOWN ON ITS OWN AND WILL NOW POWER UP.
Mar 14, 2008 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
703 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
