Re: TP-LINK TL-WA730RE is not allowing internet access...
Yeah same here. You have to find a way to give the DNS settings to WA730RE. 2 Options or use the Dynamic mode of getting the ip in the WA730RE or use a custom firmware where u can configure this setting.
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Here's a GuessYa. Make sure you have the correct and exact DNS servers. If you screw them up, you'll be able to get cached pages, but new pages or functions will crash. It's a funny thing when you find it for the first time :-)
Do this with the new one turned on and then do it with it turned off.. I'm thinking it will show two different numbers.. They should be the same .. You can manually change the default gateway to the one that works.. But sounds like the range extender isn't set up properly. May need to do some manual config.
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Your friend is able to go online using the same wireless network. that means the wireless network is working properly and there might be a problem with your computer . You said that you can connect to the wireless network but you can not go online. Check the IP address and the default gateway of the computer. Try to ping the router and DNS server and check what happens. Make sure that there is no static IP address on the computer.
Click Here for more information about the routers and Internet.
