Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
I can't unlock my Zune.
When i try to turn it by turning from the play and pause button it won't turn on. It only turns on if I plug it in to the computer w/ the usb cable and when it does turn on I press down an it doesn't scroll down it just stays on the same spot
  • 16 more comments
  • thug1 Aug 23, 2008
    my zune won't unlock i cant listen to my music it only can charge thats it
  • mlexi2003 Sep 20, 2008
    hi hi i have the same problem i can't unlock my zune player it only stays on when i have it charging to my computer .can i get a respond how to unlock it....thanx
  • devw78 Sep 24, 2008
    My Zune will only come on if it is plugged in and then it won't respond
  • buckeye0728 Oct 02, 2008
    I am having the same problem. I can update everything when it is connected but it will not work any of the buttons on the Zune its self
    The lock icon stay in the right bottom corner. I have even restored it and it is still there. Please help
  • Cathie Fehrman Nov 14, 2008
    I have the same problem where my zune only turns on when I plug it into the computer and it still won't let me scroll. It shows the that the lock is closed. I don't recall locking it and I am not for sure how to unlock it since it will not let me scroll.
  • amandaory Dec 21, 2008
    I have the same problem with my 8GB Zune. I bought it last night. Did the software installation, syncing, everything. Swithched the lock back and forth and nothing. Press the on/off button, nothing.
  • jbushing Dec 24, 2008
    it already is all the way to the left, and it still says the device is locked and only comes on when i plug in the usb or headphones
  • lizzys1972 Feb 06, 2009
    I have moved the hold button to unlocked and it still won't work?????
  • Anonymous Feb 14, 2009
    my zune's doing the same thing. its not on hold, and it wont scroll. it only charges. it's so frustrating!
  • cherishm90 Feb 14, 2009
    help!!!! i have the same problem. it is so frustrating!
  • Anonymous Feb 17, 2009
    on my zune i have to switch the lock button at least 4 times intell it actually unlocks
    how can i fix this
  • parms28 Mar 09, 2009
    Please write any solution I have same problem I even opened my zune nothing helped its still locked
  • Anonymous Mar 13, 2009
    ok how can u unlock it, if you broke the unlock key, is there a way?
    please help
  • brianh0913 Mar 16, 2009
    I am having the same issue. For days now, my Zune will lock and unlock by itself. I cannot do a reset cause every time I touch it, it locks. I would be lucky if I pressed the right button to play a song while it was unlocked for a split second. And before anyone asks, yes the slide switch is to the left (which is the unlock position), but the lock symbol at the bottom of the battery indicator switches by itself from lock to pause.
  • sherylgorman Apr 25, 2009
    I have the same problem. It shows locked and is not locked. I have contacted Zune support and "Brian" the supervisor told me that I needed to send it in with $129.95 for refurbishing. What a joke. I have not even used my Zune except about 15 minutes when I first got it. Now a year later ready to take it on a trip .... and it does not work. And, there is absoutely no support from Zune. I am ready to file a class action lawsuit....any interest? From googling this it looks like there are MANY of us involved with a defective product!!!
    Same problem here
  • Anonymous Apr 26, 2009
    zune's **** me off. period. >: it wouldn't work over christmas break, and then it decides to work again. and it's been about 2 months now it hasnt worked, and i was so excited when it turned on today- hopes crushed once it wouldn't respond to any buttons. -_-
  • theresa823 Apr 27, 2009
    my daughter and I each have a zune and they are both frozen.
  • 6 Answers
It is not that hard, simply move the switch on the to of the zune to the left so that you cannot see any red!!!!!
Posted on Nov 26, 2008
I just called the Zune support and they helped me with this fix. What I did was Hold the Back Arrow and the top of the Center button at the same time for about 5 seconds. By doing this you will reset the device.
When I did this my Zune turned back on and worked just fine. Hope this helps.
Posted on Feb 06, 2010
  • angel_kymer
    angel_kymer Jul 21, 2012
    Thank you! This worked like a charm and I am up and running again.
I had this problem and the solution for me was containing with within darthduggan's comment "it is not that hard, simply move the switch on the to of the zune to the left so that you cannot see any red!!!!!"
My button on the top did not show any red, but simply switching it back and forth unlocked the device.
Posted on Mar 17, 2010
I have had the same problem i just fixed it pop off the slide switch and get a zip tie then use the small end of the zip tie and stick it into the **** at an angle towards the screen and use it to knock the switch to the left it should only take a second XD hope this helps
Posted on Apr 29, 2010
Call 1-877-GET-ZUNE I just did and requested an operator and told'm that i'm not the only one and i've found thousands of other people online are having the same issue. He put me on hold for a minute and spoke to someone in his office then came back and said yep go ahead and send it to us. I asked if they were gonna send me a prepaid shipping label and he said yea if i want to wait 6 buisness days or I could go on the services.zune.net and print one off if i want and anyways mail it in to them and they'll fix it for free and have it back to me 15 calender days after they recieve it. So I hope this helps i know its frustrating but at least they're admiting blame and are willing to fix them for free. good luck!
Posted on Dec 21, 2009
The sad part about this is that I had to do what **brad2fire** stated to get the unit to work. Thanks!
Posted on Aug 13, 2010
I have the same problem. How do I fix this,
Posted on Feb 17, 2009
2 Suggested Answers
SOURCE: I can't unlock my Zune.
My lock switch broke off. so with a paper clip I took off the little plastic under the switch. with that off, i could see the small black toggle switch and i was able to set that to the unlocked position. I cant lock my zune now but the zune works.
Posted on Feb 15, 2009
Zune dont turn on
Check to see if the 'Hold' switch on the top is set in the locked position, which could be preventing you from turning it on.
OR
Hold the right button (also known as the 'play/pause' button) for a few seconds and wait for the Zune start-up screen to come up.
OR
Hold the left button (the 'back' button) and the top of the Zune-pad for a few seconds until the screen resets.
OR
Try charging it. If the battery is drained, you will see a low battery indicator on the screen.
Sep 13, 2012 | Microsoft Zune 120
Zune will not turn on
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
Mar 21, 2008 | Audio Players & Recorders
Bought a 8gb zune
OK, plug it in for about four hours, and then it should start to work. What has happened is it has frozen during standby mode. Hope this helps :-).
Dec 06, 2009 | Microsoft Zune JS8-00001 Digital Media...
My 30gig zune is froze and unresponsive. Please help
there is a "lock" button on the top on the left side make sure this switch is turned to off.
Try one or more of these solutions to resolve this problem:
  • The Zune may be locked. Move the hold switch to the unlocked position. It may help to move the switch back and forth. Then press the play/pause button for a second.
  • The battery may be drained.try recharging it
  • To reset your Zune, press and hold the back button while pressing up on the Zune pad. Resetting turns Zune off and on again.
May 27, 2009 | Microsoft Zune JS8-00001 Digital Media...
i had the same problem. my solution was easy since the circuitry of the zune is complex, i bought another motherboard & installed it & as soon as it was back together it fired right up, no problems! check out ebay for this piece. hope this helps.
Jan 19, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Dec 13, 2008 | Microsoft Zune JS8-00001 Digital Media...
ZUNE 80G BATT
Hello LB613,
It sounds like the battery is failing. Over time the amount of operating time you can expect between charges will decrease. The battery will still come up to normal voltage and thus will appear to charge normally but it will become depeleted very quickly during use.
You can contact Microsoft to get more information about a battery replacement for your MP3 player. The official Zune website is: http://www.zune.net.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 25, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune Won´t turn on
my son's just did this and the reset method worked (press the back button and up and hold both for about 10 seconds until the zune screen appears)
Nov 08, 2007 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
6,335 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
