Question about Refrigerators
Fridge not cold freezer ok westinghouse virtuoso
  • 2 more comments
  • Anonymous Oct 14, 2008
    fridge not cold and ice in it the alarm keeps going off westinghouse virtuoso temperature @-18-5c
  • margaret row Oct 14, 2008
    fridge not cold and the alarm keeps going off sit @ -17-5c
  • skylar123 Dec 17, 2008
    My kitchenaid fridge is all this suddenly not getting cold it is 67 degrees farenheight in our fridge and 38 in our freezer. it wont get cold we tried not opening it all day and all night but it stil wont work
  • cherylstein Apr 08, 2009
    My fridge is not cold. My freezer seems to be working fine. The problem seems to have started when I packed the fridge with more things than usual. However, I do not think that it is so packed that it should be causing such a problem. Any suggestions?
    Sergeant:
  • 152 Answers
More then likely your problem is that its not defrosting correctly in the freezer and the ice has built up behind the panel and not allowing the cold air down into your refrigerator.
Posted on Aug 22, 2008
Try this connect your fridge and then take all your food out and at the top there is a hex or circle bolt with groves/ a slight ramp on it , get a plastic screwdriver and turn it clockwise VERY GENTLY ITS FRAGILE .This turns the timer to defrost .During this all the water will build up and come from under the fridge due to that the draining pan over flows , clean that up and then turn the timer you should hear a click then it should start cooling again .I had this problem too GRR MAYTAG.
Second solution would be to look on the left or where ever there is fridge from the freezer and there are ducts , try to move some ice that may block this
Posted on Oct 14, 2008
5 Suggested Answers
  • 178 Answers
SOURCE: Westinghouse Virtuoso Fridge - Circuit Diagram
If it is kicking the circuit breaker out in defrost mode, then the defrost timer is faulty. It would be best to just replace the timer instead of checking the wiring schematic. Look at www.partstoday.com for helpful illustrations on parts and identifying pictures.
Posted on Mar 30, 2008
guru_fixya
  • 944 Answers
SOURCE: westinghouse virtuoso fridge is noisy
First analyze from where you are getting the sound.
1)Check the fan at the back side of the freezer.Is it making noise.Remove it and put some oil so it will rotate without sound.Check for the bending and straighten it and see it
doesn't hit on body.
2)compressor motor may vibrating a lot making noise to the condenser coils.It makes the full fridge to vibrate and makes noise.Adhesive stickers will soften them.If still problem persist coil could be damaged.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 06, 2010
SOURCE: westinghouse virtuoso fridge freezer manual
where is filter located for water and ice block dispencer on a 2003 model
Posted on Sep 23, 2010
  • 4 Answers
SOURCE: westinghouse virtuoso fridge freezer on top has
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Posted on Oct 13, 2010
Westinghouse virtuoso freezer alarm will not turn off, why?
the alarm on virtuoso/ westinghouses are generally a high temp alarm
meanning the freezer has not reached its set point temp . it could be caused by many problems . i would suggest you get a tech to diagnose it properly .
Oct 03, 2014 | Westinghouse Refrigerators
Westinghouse virtuoso fridge not working freezer is fine
Check thermostat is turned up test to see if it goes cold if not replace the thermostat .
Aug 31, 2014 | Refrigerators
Westinghouse virtuoso fridge is freezing. adjusting temp on door panel doesn't work.
Is the fan operating in the freezer section? If not there is your problem. It the fan is working then it could be the damper or the temperture control.
Feb 14, 2014 | Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
Oct 13, 2010 | Westinghouse Refrigerators
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
1,388 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
