Question about LG WM-2277HW Front Load Washer
Drain where is the drain located and how do i clean it out? Thanks for the help dennyheidi@sbcglobal.net
  • 876 Answers
The drain is located on the back of the washer. It is usually about a 2+" black hose. that is clamped onto the washer and goes into a stand pipe or a wall drain. You will have to remove it to clean it out. Be sure to turn the washer off and unplug it and have some old towels ready!
Good luck to you.
Posted on Aug 22, 2008
A/c is window mounted - tilted slightly to the outside. Water drips from the middle bottom of the unit, and onto the sill. I don't see any drain hole. Is there a drain hole that I can't see, or do I...
water should drip out back. You may need to clean floor of unit so water can run to the back
I'm happy to help.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 03, 2010 | Maytag M6X06F2A Air Conditioner
Hotpoint csx22ga refrig/freezer ice built up in bottom of freezer
Clean drain under freezer coils<br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href="mailto:imufo2@sbcglobal.net">imufo2@sbcglobal.net</a>
Aug 31, 2010 | Hotpoint Freezers
Haier air conditioner model esa408j-l it leaks water wat can i do
Clean floor under both coils inside so water can flow to the back drain or pan.
Be sure the unit tilts a bit to the rear.
Aug 24, 2010 | Heating & Cooling
There is a leak of water in front of the Air Conditioning unit
Clean floor of unit under coils so front coil water can drain under the coils to the back drain.
Don't forget to tilt them unit a bit to the back to allow the water to drain towards the back.
Aug 23, 2010 | Frigidaire FAC084N7A Air Conditioner
All of a sudden the airconditioner started filling up with water and the fan blades started spraying water out of where the air comes out. The unit is draining from the back.
Try cleaning out from under The evaporator (front) coils towards the back so the water can drain underneath the front coils towards the back
Make sure the unit is tilted a little towards the back
Clean drain hole in back too.
Aug 23, 2010 | Kenmore 75050 Wall/Window Air Conditioner
There is water dripping out of my fujitsu split air conditioner
Sounds like the drain needs cleaning if not clean the unit complete
inside pan and coils with a coil cleaner purchased at your Appliance repair store or A/C parts and Repair shop.
Don't forget to tilt the unit back a bit off level.
Aug 21, 2010 | Fujitsu 24C1 Air Conditioner
Water leaking from under the fridge
Check drain
This is a sympton of a defective refrigerator cold control (Thermostat) getting too cold and freezing drain
Also check temp of freezer should be below 10 degrees
Aug 07, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a carrier unit on the roof and it is dripping water in the bus.
Check seal around unit and clean drain
Aug 06, 2010 | Dometic Rooftop RV Air Conditioner
Cannot receive email, although I can send it.
yes, sbcglobal.net is through ATT
If you have a new email provider you can forward your email using "true switch" you can find their link on the internet, true switch will notify all of your contacts that you have a new email address
this service is free and lasts for a few months
Mar 27, 2009 | Mozilla Firefox
LG WM-2277HW Front Load Washer Logo
42 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
