Question about Seagate Barracuda (ST380215A) 80 GB IDE Hard Drive
Hard Disk hangs
Hi there. Need help. My hard disk hangs everytime it boots up, and it shows a blank screen with a blinking cursor in the upper right corner of the screen. I tried to slave it to a functioning hard disk and it causes this hard disk to also hang, it is not detected initially by the functioning hard disk but when I run "scan for hardware changes" in device manager, the failed hard disk sometimes shows up, but causes already the functioning hard disk to hang. Any advice?
  • 94 Answers
You have to give it for reairing or buy a new hard disk..
Posted on Sep 13, 2009
Problems to obtain a complete system boot at first try.
See if you can boot to safe mode. Run check disk on the hard drive. Make sure the BIOS battery is ok.
Oct 29, 2017 | Dell Computers & Internet
How can i fix my laptop cursor's blinking
FIRST:
When your computer is booting up you have the option to press F2 or F12.
PRESS F2 -Set Up
When your in the Set Up go down to Boot Device Configuration(BDC)
Now under Hard Disk Boot Priority
You Will see first boot device
second
third
and boot other device
FOR THE FIRST BOOT DEVICE SELECT "HARD DISK"
After you have made the first boot device hard disk press F10 TO SAVE and RESTART
These are the steps to follow if you have Windows Vista and are dealing with a Black Screen with Blinking underscore. :)
May 16, 2014 | Lenovo 3000 N200-0769
G42-415DX laptop - will not boot up, only gets through HP splash screen then blinking cursor on black screen. Have tried booting to Safe Mode (F8 and F5) and System Recovery (F11) with same problem -...
blinking cursor problem is the error messages to your hard disk. do troubleshooting on your hard disk by replacing the hard disk (100% fully functional) and then do the system installation
(you will get results cheer)
good luck
TQ
Sep 16, 2011 | HEWLETT-PACKARD G42-415DX Laptop
Each time I start up the computer, it only shows a black blank screen with a cursor blinking on the top right corner of the monitor
That usually happens when the computer is booting up from another drive other than the hard drive... Try pressing delete when the computer start then make sure that hard drive is selected as the primary..
Sep 09, 2011 | HP Compaq dc7600 Convertible Minitower PC...
I have a Toshiba Portege A100. When I try to start up my laptop it goes to the Toshiba screen, and then goes to a black screen with a cursor blinking in top left-hand corner, and hangs. I have tried to get...
The blinking cursor indicates that the Operating System is not loading properly, probably due to missing or corrupt file and you have to reinstall the system to fix it.
To get the data back, you have to remove the hard disk and connect it to another PC and back up the required/ vital data, after which you can put the hard disk back in the laptop and re-install it.
There are several cut-out panels at the bottom of your notebook. Remove the screws holding them in and pop them off. You may need to use a flathead screwdriver to pry the panels off. Remove the panel at the bottom left to unveil the hard disk. (Remove the screws holding the hard disk, if any) Pull the hard disk towards left corner (as shown) to unlock it from its connector to remove. Once you remove the hard disk, you would have to connect it to another PC as Portable hard disk. Its a SATA hard disk, so you need a SATA to USB interface (portable disk case). Copy the vital data to another PC and put the disk back and reinstall the Operating System afresh.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 19, 2011 | Toshiba Satellite A100-S8111TD Notebook
My Computer use windows XP Operation System. hp 540 laptop when I turn on windows, it show black screen with cursor. It cannot continue log to windows. I check in bios cannot detect hard disk. How to solve...
Open your laptop and and fix the hard disk cable.After this start laptop and check the bios if HDD detected then select boot device and select first boot device is Hard disk.Save the setting and restart the window.You are able to open your window. But If Hard disk drive is not detected change data cable,power cable of Hard disk.If hard disk is detected in bios follow upper rules. And if it is not detected again you should walk into Hard disk repairing center and check hard disk there.
Jun 07, 2011 | Computers & Internet
My Toshiba Satellite L45-S7423 PC Notebook will not star it brings me to a screen with an underscore key blinking.how do i get it started?
Hi King,
I see that you are having issue with your Toshiba and as you mentioned that you are seeing a black screen with a blinking cursor and I believe that it is on the upper left side of the screen.
Having this blinking cursor means that the machine is not booting into the Hard drive, we will check several things on your laptop to find out what is causing this on you laptop.
  • First as soon as you power your Laptop ON keep on tapping f12 to get to the boot menu, once you see the boot menu screen it will show you a list the first one should be you Hard drive it should say SATA so on ans so fort click on it then press enter this should boot into your Hard Drive but it still you get the blinking cursor then we will need to check the BIOS.
  • To get into the BIOS from shut down as soon as you power the system on keep on tapping F1 this will show you a Blue screen it may say Phoenix BIOS on the upper left side or center or may be different,
  • Once in the BIOS screen there will be tabs on top of the screen for options, look for boot check the Boot sequence and change the first boot priority to the Hard drive.
  • But doing both the instructions above will only work if the Hard drive is detected, by doing F12 for the Boot menu if the Hard drive is not on the list then the Hard Drive will most likely not be in the BIOS as well and this means that th Hard Drive on your system may need replacing.
I believe that this is a far as we can go since there is no other option to do regarding this concern, unless you would know how to open up you Laptop from beneath and re-seat it from it connection, re-seat meaning remove and reconnect.
Have a nice day I hope that I was able to provide details that can help .
Apr 07, 2011 | Toshiba Satellite L45-S7423 Notebook
Windows XP unable to load os on hard disk
Hi Friend,
You need to select your first boot option. it should be hard drive not a bios. if your system not restart then you need to restore your system...
Dec 28, 2009 | E-Machines (T2958) PC Desktop
Laptop is not booting
go back into the bios and reset the bios to defaults, hit F10 to save changes and reboot
let me know what happends
regards
Nov 24, 2008 | Lenovo 3000 Y410 Notebook
Computer won't boot
Make sure your computer detects the hard drive and is set to boot from it.
Dec 06, 2007 | Western Digital (WD3200JS) 320 GB Hard...
Seagate Barracuda (ST380215A) 80 GB IDE Hard Drive Logo
385 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
