Ideal Temperature is between 34-38 degrees Farenheit. 1 degree celcius converts to 1.8 x 1 + 32 = 33.8. This is ABOVE freezing and should be Perfect...
6 degrees Farenheit = -14.44 degrees Celcius
Water freezes at 32 degrees Farenheit or 0 degrees Celcius
Most food contains water, so what's the question?
On the Luxpro PSD111, Farenheit or Celcius are selected using the Jumper Switch J2 on the rear of the unit's circuit board:
Open = Celcius
Closed = Farenheit
This sounds like a Jacuzzi. This is hard to describe. In the control box, on the circuit board, in the upper right corner there is a small bunch of pins in 2 rows 5 or 6 in length. one set of pins have a black jumper on them, remove the jumper and temp should go to farenheit. Turn off power to spa before doing this.
